Servo Pad icon Servo Pad — Drag mouse or finger as a virtual joystick to control pan/tilt x- and y-axis servos with configurable ports, limits, inversion, and backgrounds. Try it →
There is another topic around where DJ has explained what is needed for ARC. I believe it needs to be a jpeg stream.
If video.cgi isn't working then it's probably not a jpeg stream.
here's the thread
Hello Rich ! You're everywhere ! :=)
But it works in a navigator... that's why I don't get what's going on. I've read the topic you mentioned.
What make/model camera is it?
Wansview ncb541w. Another one made by kaicong same hardware and firmware and 20$ cheaper:)
Hello and thank you again,
I still get the same JPGStream Read Error message. I notice in browser that if I previously logged off it asks me for my credentials so ther must be something with the format arroudn passwd and id. I'll test without them later on.
Thanks again Elfege
The thing is that it cannot work without a account... I should have known that. So I need to find out what the exact code may be or if I can't ill have to crate a virtual device.
