Display Popup icon Display Popup — Full-screen popup display for ARC: show custom text with configurable timeout, font, text/background color, size and position via controlCommand(). Try it →
Holland
IoTiny Dual H-Bridge PWM issue
Iotiny Dual H-Bridge PWM Issue
I’m converting my Shell-e (EZ-Robot IoTiny, Wi-Fi) to a two-wheel drive using the EZ-Robot 2.5A Dual H-Bridge and two 6V TT gear motors, and I’m stuck getting consistent speed control from the Dual HBridge w/PWM Movement Panel in ARC. Wiring is: Left motor IN1=D0, IN2=D1, ENA (PWM)=D2; Right motor IN3=D3, IN4=D4, ENB (PWM)=D5. Grounds are common between IoTiny and H-Bridge, motor power is a 2S LiPo to the H-Bridge, and logic is from the IoTiny. Jumpers are removed from ENA/ENB. In ARC, the Movement Panel is mapped to those pins, and I’m testing with the built-in Forward/Left/Right buttons and the speed slider at 30-50.
Observed behavior:
  • Forward/Reverse: both motors follow direction correctly.
  • Left/Right turns: the left motor speed responds to the slider, but the right motor seems to ignore PWM and runs full speed during turns.
  • If I swap the ENA/ENB signal wires, the issue follows the PWM pin (the other motor then ignores speed), which makes me think the H-Bridge channels are fine and the problem is pin-specific.
  • If I change the right PWM assignment in the skill from D5 to D2 and rewire, PWM works on that side, so it feels like D5 isn’t being driven as PWM by the skill.
  • I also tried D6 for right PWM with mixed results (sometimes it worked after a reconnect, sometimes it jumped to full speed). ControlCommand attempts like ControlCommand("Dual HBridge w/PWM", "SetSpeed", 40) don’t change the right motor behavior when mapped to D5.
Is there a known limitation or configuration trick for using D5 as the right-side PWM pin with the Dual HBridge w/PWM on an IoTiny, or should I remap to specific pins to get consistent speed control on both motors?
Shell-E by EZ-Robot
Shell-E 3D-printed robot kit uses Synthiam ARCx to drive, see, speak, code, and teach robotics with IoTiny and browser control
Servos 8
ADC 2
Digital 8
Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning.
Yes - this sounds much more like a pin-capability / port mapping issue on the IoTiny than a bad H-Bridge channel.
What your testing already proved
You’ve done the right isolation steps:
  • Swapping ENA/ENB makes the problem follow the PWM pin
    so the H-Bridge channel is likely fine.
  • Reassigning the right PWM to D2 makes it work on that side
    so ARC can drive PWM, but not consistently on D5 in your setup.
  • D6 giving mixed results
    suggests that port is not a reliable choice for that specific skill/configuration either.
Likely cause
On the IoTiny, not every digital port behaves the same way for PWM in every skill. Some ports are better suited for PWM output than others depending on the firmware/board mapping and what else is attached in the project.
For the Dual H-Bridge w/PWM skill, the safest approach is to use the ports that are known to work reliably for that board/skill combination.
Use the common, proven mapping:
  • IN1 = D0
  • IN2 = D1
  • ENA = D2
  • IN3 = D3
  • IN4 = D4
  • ENB = D5
but if D5 is not behaving as a true PWM output on your IoTiny, then the practical solution is to move the right PWM to another port that ARC reliably drives as PWM on your board, and update both:
  1. the skill settings
  2. the physical wiring
If D2 works consistently, but D5 does not, then yes - remap to the working ports rather than forcing D5.
Important note about ControlCommand
ControlCommand("Dual HBridge w/PWM", "SetSpeed", 40) is for the movement panel speed, not a direct per-pin PWM override. So if the skill/port mapping is the issue, changing that command won’t fix a bad PWM port assignment.
Best troubleshooting path
  1. In the Dual H-Bridge w/PWM skill, open the kebab menu (3 horizontal lines / top-right menu).
  2. Go to Settings.
  3. Confirm the PWM ports assigned there.
  4. Test with:
    • left PWM on a known-good PWM port
    • right PWM on another known-good PWM port
  5. Keep speed sliders above 0% in the skill window.
My recommendation for your build
If you want consistent behavior right now, I’d suggest:
  • keep the direction pins as-is
  • move the right PWM off D5 to the port that behaves reliably on your IoTiny
  • re-test forward, reverse, and especially turning at low speeds where PWM differences are easiest to see
Helpful references
One more thing to check
Since you’re on a Shell-e / IoTiny, can you confirm:
  • which IoTiny firmware version you’re using?
  • whether D5 is also being used by any other skill in the project?
  • whether the right motor PWM issue happens only during turns, or also when driving straight at low speed?
If you want, I can help you build the best port map for the IoTiny and suggest a cleaner wiring layout for the Shell-e conversion.
