Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Introducing. Me!
Introducing. Me!
Hello EZ-Robotiers!
So my kit arrived today and I thought it is now the best time to say a quick greeting, pass on my initial observations and ask about an extremely minor issue.
Me: So I'm an IT professional by trade with a long established love of technology and somewhat passionate about understanding the world around me. I'm a complete robot amateur but plenty of experience with programming. I'm likely to need help with components and electronics while likely to help with coding and generalised issues.
EZ-Kit: So, like I said I just got my EZ-Robot kit and it's fair to say the excitement and creative juices are rife! Everything about this product is excellent; the price, features, presentation, contents, delivery time... everything! Just a small note on the power cables for fellow UK residents though, you will need a travel adaptor to accompany your kit.
Small Problem: I ordered the bench power supply but when I plugged it in (via the travel adaptor with the supplied kettle lead) the LED on the pack didn't light up and no power to the EZB:( I whipped out the batteries and connected to battery pack and the board is fine (phew!) so thinking that either the power cord or pack is faulty, I connected a standard UK kettle cable but the pack still doesn't come to life. Any suggestions what I can try next? I thought I'd ask here before cracking it open and prodding around. We're 230V mains voltage here in the UK if that makes any difference.
tl;dr I love my new EZ-Robot kit:)
Use a multi-meter and measure the power output of the power supply.
Hey man, can't say i can help with your problem, i'm pretty new to this stuff myself, but just thought i'd say hi and nice to see a new brit on the boards:)
Best of luck getting everything up and running.
Matt
Welcome to the EZ-B world
Hello and thanks for the warm welcomes:D Where are the Brits from then? I'm from sunny Staffordshire.
@robot-doc the kettle lead (from the plug socket to the pack) seems ok, the meter shows voltage but I'm not getting a reading from the bit that connects to the EZB from the pack (barrel connector?). Any other ideas? Cheers blush
I've still had no joy with this, I'm thinking it's DOA :( I tried emailing into Tech Support but it seems they're too low on staff to take queries direct - any other ideas or shall I cut my losses and crack the power pack open for a good old fashioned diagnostic?
Hi I didnt get a bench power supply as my EZ-B orders were pre this. Is the lead from the power pack to the barrel connector all sealed? and where did you measure the voltages? I would also cut off the 2 pin plug supplied and stick on a standard UK plug its a 240v compatable device and it eliminates another potential problem with adaptors
About the only thing that you could replace yourself would be the barrel connector which may not have been made properly. A switched mode PSU like this cant really be fixed a trip to Maplins will get you something to replace it fairly cheaply or just a replacement barrel to solder on if thats the problem. Normally the EZ-B guys are pretty good at sending replacements for DOA parts check your junk inbox
The supplied kettle lead works, I ruled that out by sticking the plug into a travel adaptor and connecting it to my monitor, which powered up. Connecting my monitor cable to the power pack has no effect, so I think I can safely rule out the power cable at fault. I'll try to take a photo of where I'm measuring the voltage on the barrel from, I'm not sure I can articulate it nor am I convinced I've even done it right blush I placed on end onto the outer metal (which I presume is the ground/negative?) and the other inside the barrel (to the little pin that I presume is the live/12v feed). The barrel seems in fine condition and there are no obvious kinks in the cable itself. I've checked my Junk but I wouldn't have expected a message as the Contact form wouldn't allow me to send, predefined notice when you go to the Contact page... That said, I appreciate the cost of shipping a replacement would hit the EZ-pockets, I'd rather they get a refund from the supplier and use the cash to keep up the great work:D
Am I understanding this right that if I had any 12v DC pack that supplied 5A (and a barrel that fit) it would be ok to use as a replacement? I've got an old 'universal' laptop pack that might well do the trick if I snip the existing barrel as you suggested.
Thanks for the help and advise, I'll try to grab a photo this weekend.
