Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Inmoov Battery Question
Hello fellow Ez-Robot Users,
I am in need of some help, I have been building my Inmoov for several months when I have the time and came across this issue. I first had a e-fuel power supply 12v at 30a which I found out very quickly that it was too powerful to power my ezb4's (two that I have).
I now have a 6v 50a power supply. When I connect to the network and have both running, it does not move not of my servo's? I have tried using 5 at first then down to one, Then I disconnected the first Ezb4 and tried my second one, still nothing, I then cranked the voltage up to 7.4 to see if it would make a difference and it doesn't.
I'm scratching my head here? When I test the servo's with my ezrobot 7.4 bower battery it seems to work fine.
All the help is much appreciated.
Rob
I am using ARC to test my servos..
I managed to figure out my issues.
First thing I did was disable the lipo power saver, then I tested my right arm. Unfortunately, the servos in my left arm (fingers) are fried and now have to get some new ones, but at least my power supplies are working and moving servos.
I'm just happy things are moving forward again.
A big thanks to everyone for helping. What a great community EZrobot has here.
Rob
Ahh, so I was right. You did have bad servos. Sorry for your loss. stress Or did you manage to figure out how to disable the low power safeguard?;)
Hi Dave,
You were right, the servos are gone. I already ordered new ones and I did manage to disable the power safeguard as well.
A big thank you for your help, It is much appreciated.
Rob
No prob Rob. LOL. :) I just was curious what the final problem was. Sounds like it was a cobo. It's always harder to figure out problems we there are more than one.
I think JD hit the nail on the head regarding not disabling the low power safeguard’ for the Lipo battery.
I’ve falling for this a couple of times on my InMoov using the 6v SLA battery when creating a new project on ARC and not disabling the low power safeguard’ Also having the audio turned off on my Amp, so I don’t hear the warning message. stress
Chris.
