Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Hi This is a pretty basic question but cant seem to find the answer. Ive got my new JD robot and looked at the instructions to build it and the first instruction says:
Connect Left Shoulder to servo port D3 Connect Right Shoulder to servo port D2
how do i know which wire coming out of the chest is left shoulder and right shoulder? there doesn't seem to be any markings on them?
in the next step it then says:
Connect Horizontal to servo port D0 Connect Vertical to servo port D1
again how do i know which is the horizontal and which is the vertical?
Any help much appreciated!
Ric
ptp's got it covered! You will find the video that ptp linked to from this tutorial: https://synthiam.com/Tutorials/Lesson/71?courseId=1
To access the building instructions for the JD robot, locate the LEARN section from the top of this website. Within the learn section will be a video that explains how it works. You will find it to be quite straight forward. Simply select your robot and begin the course. Do not skip steps:)
