Hi This is a pretty basic question but cant seem to find the answer. Ive got my new JD robot and looked at the instructions to build it and the first instruction says:
Connect Left Shoulder to servo port D3 Connect Right Shoulder to servo port D2
how do i know which wire coming out of the chest is left shoulder and right shoulder? there doesn't seem to be any markings on them?
in the next step it then says:
Connect Horizontal to servo port D0 Connect Vertical to servo port D1
again how do i know which is the horizontal and which is the vertical?
Any help much appreciated!
Ric
Check this video:
0:54 Method to determine left or right shoulder
2:00 Assembly JD Head
ptp's got it covered! You will find the video that ptp linked to from this tutorial: https://synthiam.com/Tutorials/Lesson/71?courseId=1
To access the building instructions for the JD robot, locate the LEARN section from the top of this website. Within the learn section will be a video that explains how it works. You will find it to be quite straight forward. Simply select your robot and begin the course. Do not skip steps
