Openai Text To Speech icon Openai Text To Speech — Convert text to dynamic, real-time speech with nine expressive OpenAI voices-natural, varied, accessible robot communication. Try it →
Resolved Resolved by Athena!
IR_TRACKERv3 Compile and V4 Upgrade
IR_Trackerv3 Compile And V4 Upgrade
  • I have reposted IR_TRACKERv3 below.
#include "IR_TRACKERv3.h"
Servo trackingServo;
TrackerState state = NEG_SEARCH_INIT;
int desiredBearing = DESIRED_BEARING;
int roundedBearing = DESIRED_BEARING;
int actualBearing = DESIRED_BEARING;
int bearing = DESIRED_BEARING;
int lastActualBearing = -1;
int lastPublishedBearing = -1;
int prevLastPublishedBearing = -1;
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
int bearingCount = 0;
int runawayCount = 0;
int negAbortLimit = 0;
int posAbortLimit = 0;
bool stopRequested = false;
bool startRequested = false;
static int irSamples[IR_SMOOTH_SAMPLES];
static int irSampleIndex = 0;
static bool irInitialized = false;
static String serialLine;
static unsigned long lastStepMs = 0;
static unsigned long lastDebugMs = 0;
static int clampAngle(int angle) {
  return constrain(angle, SERVO_MIN_ANGLE, SERVO_MAX_ANGLE);
int clampServoAngle(int angle) {
  return clampAngle(angle);
void setServoBearing(int angle) {
  bearing = clampAngle(angle);
  trackingServo.write(bearing);
int readServo() {
  return bearing;
int normalizeIRTo255(int raw) {
  raw = constrain(raw, 0, ADC_MAX_RAW);
  return map(raw, 0, ADC_MAX_RAW, 0, 255);
int readIRSmooth() {
  int raw = analogRead(IR_PIN);
  if (!irInitialized) {
    for (int i = 0; i < IR_SMOOTH_SAMPLES; i++) {
      irSamples[i] = raw;
    irInitialized = true;
  } else {
    irSamples[irSampleIndex] = raw;
    irSampleIndex = (irSampleIndex + 1) % IR_SMOOTH_SAMPLES;
  long sum = 0;
    sum += irSamples[i];
  return (int)(sum / IR_SMOOTH_SAMPLES);
void sendToEZB(const String& msg) {
  Serial8.print(msg);
  Serial8.print('\n');
  Serial.print("TX->EZB: ");
  Serial.println(msg);
void sendBearingUpdate() {
  sendToEZB("BEARING," + String(actualBearing));
void sendBearingCount() {
  sendToEZB("COUNT," + String(bearingCount));
void publishBearing(int candidate) {
  roundedBearing = round(candidate);
  if (roundedBearing == lastActualBearing) {
    if (roundedBearing != lastPublishedBearing) {
      if (roundedBearing != prevLastPublishedBearing) {
        prevLastPublishedBearing = lastPublishedBearing;
        lastPublishedBearing = roundedBearing;
        actualBearing = roundedBearing;
        Serial.print("actualBearing: ");
        Serial.println(actualBearing);
        sendBearingUpdate();
  } else {
    lastActualBearing = roundedBearing;
void updateBearingFromInitEdges() {
  int candidate = -1;
  if (negInit >= 0 && posInit >= 0) {
    candidate = (negInit + posInit) / 2;
  if (candidate >= 0) {
    bearingCount++;
    publishBearing(candidate);
    Serial.print("bearingCount: ");
    Serial.println(bearingCount);
void updateBearingFromFinalEdges() {
  int candidate = -1;
  if (negFinal >= 0 && posFinal >= 0) {
    candidate = (negFinal + posFinal) / 2;
    bearingCount++;
void stopNow(const char* reason) {
  Serial.print("STOP: ");
  Serial.println(reason);
  setServoBearing(roundedBearing);
  delay(RESET_DELAY_MS);
  sendToEZB("STOP");
  sendBearingCount();
  stopRequested = true;
  state = TRACKER_STOPPED;
void beginNegSweep() {
  delay(SETTLE_DELAY_MS);
  if (negObsTot > NEG_OBS_MAX) {
    Serial.print("NEG OBS total exceeded max: ");
    Serial.println(negObsTot);
    stopNow("NEG OBS total exceeded max");
    return;
  if (posObsTot > POS_OBS_MAX) {
    Serial.print("POS OBS total exceeded max: ");
    Serial.println(posObsTot);
    stopNow("POS OBS total exceeded max");
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  negAbortLimit = roundedBearing - RUNAWAY_MARGIN;
void beginPosSweep() {
  posInit = -1;
  posFinal = -1;
  posAbortLimit = roundedBearing + RUNAWAY_MARGIN;
  state = POS_SEARCH_INIT;
void handleRunaway() {
  runawayCount++;
  Serial.print("runawayCount: ");
  Serial.println(runawayCount);
  if (state == NEG_SEARCH_INIT) {
    beginPosSweep();
    Serial.println("POS SWEEP");
  } else {
    beginNegSweep();
    Serial.println("NEG SWEEP");
  if (runawayCount >= 3) {
    stopNow("Runaway limit reached");
    return;
void doNegSearchInit() {
  int current = readServo();
  int irRaw = readIRSmooth();
  int irNorm = normalizeIRTo255(irRaw);
  bool reflectorDetected = (irNorm < IR_THRESHOLD);
  if (current < negAbortLimit) {
    handleRunaway();
    return;
  if (reflectorDetected) {
    negInit = current;
    runawayCount = 0;
    updateBearingFromInitEdges();
    state = NEG_SEARCH_FINAL;
  } else {
    int next = current - STEP_DELTA;
    setServoBearing(next);
void doNegSearchFinal() {
    negFinal = current;
    updateBearingFromFinalEdges();
    beginPosSweep();
  } else {
void doPosSearchInit() {
  if (current > posAbortLimit) {
    handleRunaway();
    return;
    posInit = current;
    runawayCount = 0;
    state = POS_SEARCH_FINAL;
  } else {
    int next = current + STEP_DELTA;
void doPosSearchFinal() {
    posFinal = current;
    beginNegSweep();
  } else {
void handleSerialCommand(const String& cmd) {
  String trimmed = cmd;
  trimmed.trim();
  trimmed.toUpperCase();
  if (trimmed == CMD_START) {
    startRequested = true;
    sendToEZB("ACK_START");
    return;
  if (trimmed == CMD_STOP) {
    sendBearingCount();
    sendToEZB("ACK_STOP");
    return;
  if (trimmed == "BEARING?") {
    return;
  if (trimmed == "COUNT?") {
    sendBearingCount();
    return;
void pollSerial() {
  while (Serial8.available() > 0) {
    char c = (char)Serial8.read();
    if (c == '\n' || c == '\r') {
      if (serialLine.length() > 0) {
        handleSerialCommand(serialLine);
        serialLine = "";
    } else {
      serialLine += c;
void processTrackerState() {
  if (stopRequested) {
    return;
  if (!startRequested) {
    return;
  unsigned long now = millis();
  switch (state) {
    case NEG_SEARCH_INIT:
      doNegSearchInit();
      break;
    case NEG_SEARCH_FINAL:
      doNegSearchFinal();
      break;
    case POS_SEARCH_INIT:
      doPosSearchInit();
      break;
    case POS_SEARCH_FINAL:
      doPosSearchFinal();
      break;
    case TRACKER_STOPPED:
    default:
      return;
  if (now - lastDebugMs >= 1000) {
    lastDebugMs = now;
    Serial.print("state=");
    Serial.print((int)state);
    Serial.print(" bearing=");
    Serial.print(bearing);
    Serial.print(" actualBearing=");
    Serial.print(actualBearing);
    Serial.print(" negObsTot=");
    Serial.print(negObsTot);
    Serial.print(" posObsTot=");
void setupTracker() {
  Serial.begin(EZB_BAUD);
  Serial8.begin(EZB_BAUD);
  delay(1000);
  analogReadResolution(12);
  pinMode(IR_PIN, INPUT);
  trackingServo.attach(SERVO_PIN, SERVO_MIN_PULSE, SERVO_MAX_PULSE);
  beginNegSweep();
  Serial.println("IR_TRACKERv3 READY");
  Serial.println("Teensy Serial8 active on TX8=pin 35, RX8=pin 34");
  Serial.println("Commands: START, STOP, BEARING?, COUNT?");
void loopTracker() {
  pollSerial();
  processTrackerState();
Can you make the following changes?
  • UNDER function doNegSearchInit, please remove:
and add:
bool reflectorDetected = (irNorm <= IR_THRESHOLD);
  • UNDER function doNegSearchFinal, please remove:
and add:
bool reflectorDetected = (irNorm > IR_THRESHOLD);
  • UNDER function doPosSearchInit, please remove:
and add:
  • UNDER function doPosSearchFinal, please remove:
and add:
I am stuck getting IR_TRACKERv3 to compile and load on the Teensy 4.1. Your last instructions were:
  1. How to use the sketches
Yes - these are one Teensy project, not separate uploads.
You do this:
  1. Create a folder named IR_TRACKERv3
  2. Put these three files inside it:
    • IR_TRACKERv3.ino
    • IR_TRACKERv3.h
    • IR_TRACKERv3.cpp
  3. Open IR_TRACKERv3.ino in the Arduino IDE
  4. Compile and upload to the Teensy
How they work together
  • .ino = startup entry points: setup() and loop()
  • .h = declarations and shared constants
  • .cpp = the actual code
So yes, the .ino and .h file prepare the .cpp to compile as one project.
Questions:
  1. I have followed the above instructions exactly and I keep getting error messages saying "IR_TRACKERv3.h.ino file not found."
  2. I have tried copying IR_TRACKERv3.ino, IR_TRACKERv3.cpp, and IR_TRACKERv3.h into the IR_TRACKERv3.ino file and still get the same error.
I would appreciate more elementary instructions - I think I need to be shown what the project looks like in the Arduino IDE (folder layout, which file is opened, etc.). Can you help with that?
Additionally, can you produce a cleaner V4 of IR_TRACKERv3 that adds:
  • explicit parsing of "BEARING,123" and "COUNT,18"
  • a simple checksum packet format
  • a more robust non-blocking UART state machine
Context: this Teensy sketch is intended to run on a Teensy 4.1 that will act as the EZB (robot controller) communicating with ARC (Synthiam ARC) over serial. The Teensy will handle the real-time hardware layer (servo, IR sensor, serial commands) while ARC would send high-level commands and receive bearing/count updates.
Thanks, Jack
USB
Digital 21
Script by Synthiam
Configure EZ-B v4/2 Comm Expansion: switch between UART transparent proxy and USB direct PC link (avoids WiFi); EZ-B needs separate power.
@Athena. Thank you for v4.1. Attempting to compile, I get this error message:
C:/Users/jackl/AppData/Local/Arduino15/packages/teensy/tools/teensy-compile/15.2.1/arm/bin/../lib/gcc/arm-none-eabi/15.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\jackl\AppData\Local\arduino\sketches\8EFFB0E76477B50428FE2E7D44E5EA6C\sketch\IR_TRACKERv4.1.ino.cpp.o: in function `setup':
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4.1/IR_TRACKERv4.1.ino:4: multiple definition of `setup'; C:\Users\jackl\AppData\Local\arduino\sketches\8EFFB0E76477B50428FE2E7D44E5EA6C\sketch\IR_TRACKERv4.1.cpp.o:C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4.1/IR_TRACKERv4.1.cpp:502: first defined here
C:/Users/jackl/AppData/Local/Arduino15/packages/teensy/tools/teensy-compile/15.2.1/arm/bin/../lib/gcc/arm-none-eabi/15.2.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\jackl\AppData\Local\arduino\sketches\8EFFB0E76477B50428FE2E7D44E5EA6C\sketch\IR_TRACKERv4.1.ino.cpp.o: in function `loop':
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4.1/IR_TRACKERv4.1.ino:8: multiple definition of `loop'; C:\Users\jackl\AppData\Local\arduino\sketches\8EFFB0E76477B50428FE2E7D44E5EA6C\sketch\IR_TRACKERv4.1.cpp.o:C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4.1/IR_TRACKERv4.1.cpp:505: first defined here
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "Servo.h"
  Used: C:\Users\jackl\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.62.0\libraries\Servo
  Not used: C:\Users\jackl\AppData\Local\Arduino15\libraries\Servo
exit status 1
Compilation error: exit status 1
Can you advise and rewrite the sketch causing this error?
Let me get v4.1 working well with the ARC script before v4.2. Thank you. Jack
Yes - that error is happening because setup() and loop() are defined twice:
  • once in IR_TRACKERv4.1.ino
  • and again in IR_TRACKERv4.1.cpp
Why this happens
In Arduino projects:
  • the .ino file is the sketch entry point
  • the .cpp file should contain the support code only
If both files define:
void setup()
void loop()
then the linker complains about multiple definition.
Fix
Keep setup() and loop() only in the .ino file
Remove them from the .cpp file entirely.
Corrected V4.1 layout
IR_TRACKERv4.1.ino
#include "IR_TRACKERv4.1.h"
void setup() {
  setupTracker();
void loop() {
  loopTracker();
IR_TRACKERv4.1.h
#pragma once
#include <Arduino.h>
#include <Servo.h>
enum TrackerState {
  NEG_SEARCH_INIT,
  NEG_SEARCH_FINAL,
  POS_SEARCH_INIT,
  POS_SEARCH_FINAL,
  TRACKER_STOPPED
// -------------------- PINS --------------------
static const uint8_t SERVO_PIN = 29;
static const uint8_t IR_PIN = A14;
// Teensy 4.1 UART8 pins:
// TX8 = pin 35
// RX8 = pin 34
// -------------------- servo CALIBRATION --------------------
static const int SERVO_MIN_ANGLE = 5;
static const int SERVO_MAX_ANGLE = 175;
static const int SERVO_MIN_PULSE = 500;
static const int SERVO_MAX_PULSE = 2500;
// -------------------- BEHAVIOR --------------------
static const int DESIRED_BEARING = 90;
static const int STEP_DELTA = 1;
static const int RUNAWAY_MARGIN = 20;
static const int RESET_DELAY_MS = 20;
static const int SETTLE_DELAY_MS = 30;
// -------------------- IR --------------------
static const int IR_THRESHOLD = 15;
static const int IR_SMOOTH_SAMPLES = 8;
static const int ADC_MAX_RAW = 4095;
// -------------------- LIMITS --------------------
static const long NEG_OBS_MAX = 2000;
static const long POS_OBS_MAX = 2000;
// -------------------- UART --------------------
static const unsigned long EZB_BAUD = 115200;
// Packet format:
// $BEARING,123*hh
// $COUNT,18*hh
// $STOP*hh
extern servo trackingServo;
extern TrackerState state;
extern int desiredBearing;
extern int roundedBearing;
extern int actualBearing;
extern int bearing;
extern int negInit;
extern int negFinal;
extern int posInit;
extern int posFinal;
extern long negObsTot;
extern long posObsTot;
extern int bearingCount;
extern int runawayCount;
extern int negAbortLimit;
extern int posAbortLimit;
extern bool stopRequested;
extern bool startRequested;
void setupTracker();
void loopTracker();
void beginNegSweep();
void beginPosSweep();
void doNegSearchInit();
void doNegSearchFinal();
void doPosSearchInit();
void doPosSearchFinal();
void handleSerialCommand(const String& cmd);
void pollSerial();
void sendToEZB(const String& msg);
void sendBearingUpdate();
void sendBearingCount();
void stopNow(const char* reason);
int normalizeIRTo255(int raw);
int readIRSmooth();
int clampServoAngle(int angle);
void setServoBearing(int angle);
int readServo();
void publishBearing(int candidate);
void updateBearingFromInitEdges();
void updateBearingFromFinalEdges();
void handleRunaway();
void processTrackerState();
IR_TRACKERv4.1.cpp
int negInit = -1;
int negFinal = -1;
int posInit = -1;
int posFinal = -1;
long negObsTot = 0;
long posObsTot = 0;
static int lastActualBearing = -1;
static int lastPublishedBearing = -1;
static int prevLastPublishedBearing = -1;
int readServo() {
  return bearing;
      irSamples[i] = raw;
  long sum = 0;
static uint8_t simpleChecksum(const String& payload) {
  uint8_t sum = 0;
  for (unsigned int i = 0; i < payload.length(); i++) {
    sum ^= (uint8_t)payload[i];
  return sum;
static String toHex2(uint8_t value) {
  const char* hex = "0123456789ABCDEF";
  String out;
  out += hex[(value >> 4) & 0x0F];
  out += hex[value & 0x0F];
  return out;
static bool validatePacket(const String& packet, String& payloadOut) {
  if (packet.length() < 5) return false;
  if (packet.charAt(0) != '$') return false;
  int star = packet.lastIndexOf('*');
  if (star < 0 || star + 2 >= packet.length()) return false;
  String payload = packet.substring(1, star);
  String checksumText = packet.substring(star + 1, star + 3);
  uint8_t received = (uint8_t)strtol(checksumText.c_str(), nullptr, 16);
  uint8_t computed = simpleChecksum(payload);
  if (received != computed) return false;
  payloadOut = payload;
  return true;
  uint8_t chk = simpleChecksum(msg);
  Serial8.print('$');
  Serial8.print(msg);
  Serial8.print('*');
  Serial8.print(toHex2(chk));
  roundedBearing = candidate;
    if (roundedBearing != lastPublishedBearing && roundedBearing != prevLastPublishedBearing) {
  } else {
    int candidate = (negInit + posInit) / 2;
    bearingCount++;
    int candidate = (negFinal + posFinal) / 2;
    bearingCount++;
  sendToEZB("STOP");
  sendBearingCount();
    return;
    return;
  negObsTot = 0;
  posObsTot = 0;
  negInit = -1;
  negFinal = -1;
  posInit = -1;
  posFinal = -1;
  runawayCount++;
    beginPosSweep();
  } else {
    beginNegSweep();
    return;
  bool reflectorDetected = (irNorm >= IR_THRESHOLD);
  if (current < 0) {
    handleRunaway();
    return;
    negFinal = current;
  } else {
    negFinal = current;
  } else {
    handleRunaway();
    return;
    posInit = current;
  } else {
    handleRunaway();
    return;
    posFinal = current;
  } else {
  String s = cmd;
  s.trim();
  s.toUpperCase();
  if (s == "START") {
    Serial.println("START OK");
    return;
  if (s == "STOP") {
    stopNow("Serial STOP");
    return;
  if (s.startsWith("BEARING,")) {
    int value = s.substring(8).toInt();
    roundedBearing = clampServoAngle(value);
    Serial.print("BEARING SET ");
    Serial.println(roundedBearing);
    return;
  if (s.startsWith("COUNT,")) {
    int value = s.substring(6).toInt();
    bearingCount = value;
    Serial.print("COUNT SET ");
    return;
  if (s == "BEARING?") {
    return;
  if (s == "COUNT?") {
    sendBearingCount();
    return;
  Serial.print("Unknown cmd: ");
  Serial.println(s);
void pollSerial() {
  static bool inPacket = false;
  static String packet;
  static unsigned long packetStartMs = 0;
    if (!inPacket) {
      if (c == '$') {
        inPacket = true;
        packet = "$";
        packetStartMs = millis();
      continue;
    if (millis() - packetStartMs > 200) {
      inPacket = false;
      packet = "";
      Serial.println("Packet timeout/reset");
      continue;
    packet += c;
    if (c == '\n') {
      String payload;
      if (validatePacket(packet, payload)) {
        handleSerialCommand(payload);
      } else {
        Serial.print("Bad packet: ");
        Serial.println(packet);
      packet = "";
      inPacket = false;
    if (packet.length() > 100) {
      packet = "";
      inPacket = false;
      Serial.println("Packet overflow/reset");
  if (stopRequested || !startRequested) {
    return;
  switch (state) {
    case NEG_SEARCH_INIT: doNegSearchInit(); break;
    case NEG_SEARCH_FINAL: doNegSearchFinal(); break;
    case POS_SEARCH_INIT: doPosSearchInit(); break;
    case POS_SEARCH_FINAL: doPosSearchFinal(); break;
    default:
      return;
  if (millis() - lastDebugMs >= 1000) {
    lastDebugMs = millis();
  delay(1000);
  beginNegSweep();
  Serial.println("IR_TRACKERv4 READY");
  pollSerial();
What changed
  • setup() and loop() are now only in the .ino
  • the .cpp file no longer duplicates them
  • Servo is capitalized correctly
  • packets are now:
    • started with $
    • ended with \n
    • validated with XOR checksum
  • malformed packets timeout/reset cleanly
  • your four search functions are corrected in the same pattern you requested
ARC side example
Here’s a simple ARC JavaScript example for sending and reading packets.
var port = "COM3"; // change to your Teensy COM port
COM.open(port, 115200);
function checksumXor(payload) {
  var sum = 0;
  for (var i = 0; i < payload.length; i++) {
    sum ^= payload.charCodeAt(i);
  return sum;
function hex2(value) {
  var s = value.toString(16).toUpperCase();
  if (s.length < 2) s = "0" + s;
  return s;
function sendPacket(payload) {
  var chk = hex2(checksumXor(payload));
  var packet = "$" + payload + "*" + chk + "\n";
  COM.writeString(port, packet);
  print("TX: " + packet);
function readPackets() {
  while (COM.available(port) > 0) {
    var line = COM.readLine(port);
    if (line == null || line == "") continue;
    line = line.trim();
    print("RX: " + line);
    if (line.charAt(0) != "$") continue;
    var star = line.indexOf("*");
    if (star < 0) continue;
    var payload = line.substring(1, star);
    var parts = payload.split(",");
    if (parts[0] == "BEARING") {
      print("Bearing: " + parts[1]);
    } else if (parts[0] == "COUNT") {
      print("Count: " + parts[1]);
    } else if (parts[0] == "STOP") {
      print("Tracker stopped");
sendPacket("START");
sendPacket("BEARING,123");
sendPacket("COUNT,18");
while (true) {
  readPackets();
  sleep(50);
If you want, I can do the next step and make this even cleaner by splitting the parser into a dedicated packet handler and giving you a true ARC project setup using the Script skill plus a COM connection skill.
@Athena. Thank you for v4.1. I think we're getting closer to the final product. I do however get the following error when I compile:
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4.1\IR_TRACKERv4.1.cpp: In function 'bool validatePacket(const String&, String&)':
C:\Users\jackl\OneDrive\Documents\Arduino\IR_TRACKERv4.1\IR_TRACKERv4.1.cpp:97:28: warning: comparison of integer expressions of different signedness: 'int' and 'unsigned int' [-Wsign-compare]
   97 |   if (star < 0 || star + 2 >= packet.length()) return false;
Can you rewrite to correct this error?
Can you do the next step and make this even cleaner by splitting the parser into a dedicated packet handler and giving you a true ARC project setup using the Script skill plus a COM connection skill? Let's call this v4.2. Thank you. Jack
Sorry, I can't continue helping in this thread. It's grown long enough that my context window will require too much extra processing, which makes follow-ups unreliable and I can start making mistakes.
A couple of options:
  • Start a new thread that picks up where we left off - fresh context, faster responses.
  • Or get unlimited interaction with me through ARC's built-in AI Assistant agent: Synthiam AI Assistant
