HT16K33 Animator (8X8) icon HT16K33 Animator (8X8) — Control for Adafruit 8x8 LED Matrix (HT16K33) via EZ-B v4 I2C; creates animations, supports module initialization and EZ-Script control. Try it →
Pakistan
I2c In C# Not Reading Values
I have mpu-6050 6dof imu. I want to read the value of who_am_i register with register number 0x75. The register returns address 0x68. But I am getting 255. The device address is 0x68 as well. Code is as follows:
byte[] ret = ezB_Connect1.EZB.I2C.Read(I2C.ReadArgsEnum.Auto,0x75,1);
here is the register description for the device:RM-MPU-6000A.pdf
I checked my imu with arduino and it works fine. So, any help here?
You got it working? Can you share your code please:)
Sure! But it will take a couple of days in applying the filter and all, then I would share the final product!:)
awesome! I'm looking forward to seeing your success:D
Hi I have mpu-6050 too and i try to read the value from C# and i have some problems...
I tried this command : ezB_Connect1.EZB.I2C.Read(I2C.ReadArgsEnum.Auto,0x75,1); and it does't work cause there is this method "I2C.ReadArgsEnum.Auto" more over the read method accept only 2 values.... Does it exist some where a sample to use the device mpu-6050 by using C# ?
confused confused
Please share your code.
Also, in visual studio there is auto complete, which shows you the command syntax as you type.
Removed duplicate thread.
ps, i upgraded the EZ-SDK today - ensure you upgrade as well.
Now that i'm in front of a PC, here's example code...
  public class MPU6050Example {
    MPU6050  _mpu;
    public FormMPU6050() {
      InitializeComponent();
     // Create the mpu6050 object
     // Include a reference to the EZB (most likely in your EZB Connection UserControl)
      _mpu = new MPU6050(ucEZBConnect1.EZB);
    private void btnInit_Click(object sender, EventArgs e) {
      // Init is required before you can begin obtaining data
      _mpu.Init();
    void getData() {
      try {
        EZ_B.Classes.MPU6050Cls response = _mpu.GetData();
        // do something with the data
      } catch (Exception ex) {
        // handle your exception
      } finally {
Hi DJ Sures You are credible :-) , i just ask a new api and you made it in few minutes. thank you very much. I have included your code in my visual studio and tried to print the value of the Gyro but the values of the gyro are initials
label2.Text = response.GyroX.ToString(); // value 0 label3.Text = response.GyroY.ToString(); // value 0
there is something wrong in my code i think. i keep on to look for and keep you inform thank you again. tired
