How to install app on mobile
How To Install App On Mobile
Hello,
I am using the ARC app(iOS on an iPad) with a JD EZ-Robot and none of the "Installed Robot Apps" are available after signing in via "Preferences".
I can sign-in just fine and connect the App to the Robot but none of the "Installed Robot Apps" are installed.
We have been using the App and Robots without issue since last August and last week we went to use them with a summer camp we run and now it says there are no robot apps installed.
The app is updated, we uninstalled and reinstalled the app, the iPads are updated, and I even tried it with a JD that had a firmware updated pushed to it.
Hello,
Let's troubleshoot this issue step-by-step. It sounds like your ARC app signs in correctly and connects to your JD, but it doesn't show your installed robot apps. Here are some things to try:
  1. Verify Your Account
      Confirm you’re signing in with the same ARC account you used previously. Sometimes if you’re using a different account (or if credentials changed) the installed apps list may not load correctly.
  2. Check the Preferences in the ARC App
      In the ARC app on your iPad, go to the Preferences screen.
      Look for any settings related to "Installed Robot Apps" or "Robot Skills" and verify that no filters or toggles are hiding these apps.
      Ensure that the app isn’t filtering out robot apps by accident.
  3. Sign Out and Sign In Again
      Try signing out of your ARC account in the app and then signing back in. This forces a refresh of your profile and the associated robot apps list.
  4. Reset the App’s Cache
      Although you’ve reinstalled the app, sometimes settings and cache aren’t fully cleared on iOS. If there’s an option in the preferences to "Clear Cache" or "Reset Settings," give that a try.
  5. Double-Check Your Network Setup
      Since the installed apps list is managed through the cloud, make sure your iPad has a solid internet connection so that the ARC app can sync with your account data.
  6. Confirm the Installed Apps on a PC Version (if available)
      If you have access to ARC on a PC, check that your account’s installed robot apps appear correctly there. This can help determine if the issue is specific to the iPad app.
  7. Firmware and Updates
      You mentioned trying a JD with updated firmware. Ensure that both the robot firmware and the ARC app are fully updated. Sometimes a mismatch can hide certain features.
  8. Temporary Glitch?
      Since you’ve used the system without issues before, it might be a temporary glitch. Try restarting your iPad, then open the ARC app and see if the robot apps load as expected.
If after these steps you still don’t see any installed robot apps, please let us know more details about your ARC app version and any other error messages you might see. We want to make sure you can get back to using your JD-especially if you’re preparing for an upcoming summer camp.
Feel free to ask further questions or provide additional details if the issue persists!
#3   — Edited
The list of "installed robot apps" is empty because you do not have any robot apps installed. You can browse public robot apps to find your preferred JD robot app. This video tutorial will help you get started.
Additionally, the EZ-Robot website offers dozens of tutorials to help you learn how to use and program the EZ-Robot JD robot for educational and fun purposes. Here is the link: https://www.ez-robot.com/learn-robotics-getting-started-humanoid-robot-kit.html
Based on the information from Synthiam_Support, the behavior you're seeing is expected if no robot apps have been installed on your account. In other words, the list is empty because you do not currently have any robot apps installed on your account.
Here’s what you can do next:
  1. Browse Available Robot Apps
    Visit the EZ-Robot website or the ARC app store section to browse public robot apps. This is where you can select and install your preferred JD robot app.
    You can start here: EZ-Robot Getting Started with the Humanoid Robot Kit
  2. Install a Robot App
    Once you’ve found a robot app you’d like to use, follow the installation instructions provided in the app’s tutorial. This will add the robot app to your account and you should start seeing it in your ARC app under Preferences.
  3. Tutorials & Learning Resources
    The EZ-Robot website offers dozens of tutorials to help you learn how to use and program the JD robot for educational and fun purposes. These can guide you through the process of installing and using robot apps, as well as give you extra tips.
If you were previously using a custom set of apps or a custom configuration, double-check that the correct account is logged in and that there hasn’t been any change in the available apps list due to a recent update. If you need any more help installing or choosing an app, feel free to ask!
Is there any particular robot app or tutorial you’d like more details about?
#josh-gallo
hi start youre question like this   #Athena .
#Athena
Hi there! It sounds like you might have a question related to installing or managing robot apps on your ARC mobile app. Could you please clarify what you'd like to know or what issue you're experiencing? For example:
  • Are you trying to install a new public robot app on your account?
  • Are you having trouble finding apps after signing in?
  • Do you need guidance on how to browse and install JD robot apps from the EZ-Robot website?
Let me know so I can provide you with the best assistance!
When using the ARC app(iOS version), none of the Installed Robot Apps are showing up.
App was signed into in the Preferences tab and the the JD robot is connected via WiFi.
The iPad is updated and the app is updated as well.
Why are the Installed Robot Apps not showing up?
Below are a few steps to help troubleshoot why the Installed Robot Apps (Robot Skills) might not be showing up in the ARC app on your iPad:
  1. Verify Network Connection
    • Ensure that both your iPad and your robot (JD) are connected to the same WiFi network.
    • Sometimes a misconfigured network or firewall can prevent proper syncing.
  2. Refresh Synchronization
    • ARC relies on an internet connection to download and update its robot skill list.
    • Try closing and reopening the ARC app on your iPad to force a resync.
    • Occasionally, signing out of your account in the Preferences tab and signing back in can help trigger the update.
  3. Check for Sync Issues
    • If the app was recently updated (or if your device OS was updated), it might take a few moments for the installed robot apps to appear.
    • Verify that your iPad has a stable internet connection during this sync process.
    • You can find more details on how ARC synchronizes robot skills in our guide: Syncing and Updating Robot Skills.
  4. Robot Skill Manager on Desktop Version
    • If you have access to ARC on a desktop, check the robot skill Manager to ensure that your Installed Robot Apps are correctly installed and updated.
    • Sometimes syncing issues on the mobile app can be resolved by first updating on the desktop version.
  5. App Permissions and Updates
    • Double-check that the ARC app on your iPad has all the necessary permissions enabled.
    • Make sure both your iPad OS and the ARC app are fully updated.
If none of these steps resolve the issue, please let me know any additional error messages or behaviors you’re experiencing. I'm here to help guide you further!
