DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
How To Waterproof Ez-B?
i have took a look at multiple ways to waterproof electronics but came up empty. i need to find a way to waterproof it as my ez-b will be in a rc car(outdoors) and will be exposed to moisture.
Ideas: Air-tight sealed container with plastic melted around cable slots
Plasta-dip
any ways or tips will be apreciated
also technopro i dont know what you design is but what about other electronics and motors from water or moisture
sensors like SONAR'S cant be waterproof ,unless you buy a waterproof sonar that maxbotic does carry
motors are hard,and ESC's TOO ,everything else should be ok to waterproof them
well... maybe i need to refraise.
i want to make the ez-b moiture repellent.
another idea is put one of those anti-moisture packets from shoe boxes in the rc car with it.
I see i am not only one with a spelling problem lol anti-moisture idea should work ok
