Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
Use the shortcut creator to make a shortcut which can include one script to auto start on load. Shortcut creator is in ARC's menu under options.
Or you could just say the file and then the script name when you make a new shortcut via windows.
You could if you wanted to manually create the shortcut with the target syntax as follows;
"PathToEZBuilder\ARC.exe" "PathToProject.ezb" "AutoStartScript"
The script has to be a script not part of script manager.
Look at the very bottom of the EZ-Script manual for the explanation.
Way cant you just place a ControlCommand pointing to the script in the Init script control? It will then run each time ARC loads along with any other script you have in there.
Yes you can:) My init script basically runs a bunch of other scripts which are all in the script manager, turns on the camera and tracking, unpauses vr and personality generator... and a whole load more.
