Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
Hifive - Good Things Come In Two's
Well, HiFive has been repaired. Firmware 15.3 is available for download again.
The bug was between the two different bluetooth modules from the two versions between 3.1 and 3.0. The differences are minor, and not many can recognize them. But there is a strangeness with the bluetooth communication that we discovered today:)
The great thing about the 15.3 binary is the file size. It's 22,200... So as the chinese say, good things come in 2's:D ... Let's hope this is the one! I think you'll be very happy with this new firmware.
If you had been a victim of the buggy 15.3, it'll be a bit of trouble. You'll need to recycle the power quickly once to receive a pulsating LED, rather than the steady LED.
Still no luck with mp3 trigger.
Hi DJ,
I have the buggy 15.3. I am not sure what you mean about cycling power quickly..when does that need to happen?...and will this be needed everytime? On powerup I have pulsing heartbeat....but when I connect, BT only stays connected for about 5 seconds..then disconnects. I have also removed and re-added the BT adapter and re-paired...no luck.
v/r
Kevin
I don't want to tell you what to do. But, I will tell you what works for me. You plug the power in and then out and then back in again. This could be dangerous to your cpu. Then try to connect as soon as possible. I get the software all ready where I can just hit a connect button. A percentage of the time, it will connect. If it doesn't repeat the procedure. This is only a temporary fix, but it does connect eventually. I have had to do this between three and twenty times.
Hope that this helped.
Mel
@ MovieMaker,
Are you saying to do this with the Firmware Update software?
It is not clear from the forums if the firmware or the sofware was buggy..or both?
I did the power cycle to try to reload the firmware...when i do I get the following:
Connected Your EZ-B has the latest firmware. There is no need to update.
I click the upgrade button and get this:
sending ping sending ping ?sending bootloader Starting Boot Loader...
Failed to load bootloader! Have you selected the correct EZ-B COM port? Use the Help menu option to view the online help and watch a video demonstration.
Now when I try to launch ARC (the fixed one) I get the follwoing: Invalid Firmware Version. Please Upgrade. EZ-B Reports v1. This copy of ARC requires v15.3
Any ideas?
v/r
Kevin
@ DJ Thank you DJ , you solved my problem. You are just a whiz !!!!!!! Everything is running great ( he says with fingers crossed). All the improvements are GREAT! At least the ones I've tried thus far. Thank you !!!!!!!
I know you are busy, any chance of a revised manual or some videos of the new features?
Will
#15
@KKEAST,
   I installed new ARC and ALSO firmware. I think it was the FirmWare that was Buggy.
I think you need to run the program EZB Firmware Update. This can be found in the Startup Menu under Programs/ ARC. this will update your firmware. But, it has to hookup to the right com port. Most of our ports have changed. ie; my port was on Port#3 but now is on #5.
Hope that this helped you Kevin.
Mel
#16
@Mel,
Yes it does and confirms what I did. Thanks! I finally got it to update I believe. I am experiencing problems with some of the digital ports and there are several others reporting this as well. It appears the higher number ports D14 and up will sporadically toggle high. We shall see how this works out...but it currently makes my H Bridge on my bot not work correctly. I have no doubt DJ and his crew will be looking at this.
v/r
Kevin
