NMS Faux Odometry icon NMS Faux Odometry — Estimate pose odometry from movement distance for robots without encoders, calibrated by speed. Suited for DIY navigation; pose drifts with lidar. Try it →
Singapore
Hi Hi! Need To Know (push Button)
Hi Hi! Need To Know (Push Button)
Hi Guys,
I honestly am going to buy the ez-robot kit, but need to know 1 very important (to you simple, to me noob not) thing
Is it possible to add a push button (you buy from electronics store) to the kit?
I need to make two servos move in one direction when you press the button, and then when you press it again, the two servos move back into their initial position.
Much appreciated,
Can't wait to recieve my package:)
:) confused
PS: Basically I'm using the kit to make my cosplay helmet's faceplate move up, and then back into original position, but cannot use the awesome features such as wii mote control or logitech controller as I would not be able to fit them anywhere.... Thank you so much
Yes you can add a pushbutton to the EZ-B's digital ports I believe. Just like you would to an Arduino. And then using ARC you can set the function of the button using a simple script.
*Someone else should check me on this I am new to EZ-B platform and not 100% sure
United Arab Emr
Yes, it is very easy and even can be voice activated . However, remember you need a pc also. EZB is not a standalone controller.
I'm using the ADC ports. Feeding the 5vcd right from the 5vdc EZB pin that's in line with the ADC pin through the switches, when the switch (or button) is opened or closed ARC will see the change in voltage and run the script you want to run.
Thanks for the answers guys!:)
Leaves me with more questions though....
Hey hhammoud, does that mean I can't take the EZ board on its own, stuff it inside my cosplay helmet, and then run it off the AA batteries? (Installed standalone in my helmet, press the button and be awesome?)
confused
Basically I want it to do this, when I'm outside and wearing the suit, with just the batteries and a push of a button.
Just need your confirmation before I send my card details.:)
:P
Don't forget the EZ-B needs a PC too, it's not a stand alone piece of kit.
Hi Rich,
As in you need a PC to programme it? Or you need a PC just to make it do the actions and MUST have the PC at all times?
I have a laptop (typing on it now).....
Thanks so much, I'm confused now.
Must have a PC at all times. Laptop is fine. Just make sure you have made allowance for the PC in the suit. Onboard Mini ITX boards are often used on robots, you may need to adjust the suit a bit to fit one on it, or just have one nearby. The EZ-B connects wirelessly via bluetooth (as standards, however can be upgraded to wifi, USB etc.)
