Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
When it stops blinking is it solid red or is it off?
It sounds like it is establishing a connection but then almost immediately dropping the connection. This could be a few things...
Check it's set up on the PC correctly and that you are using the native windows BT stack. Also, it appears that Windows 8.1 can cause issues with the BT, have you updated to 8.1 recently?
Check your power source. A low battery or a high demand on the EZ-B may cause the connection to drop out. Try disconnecting everything from the EZ-B and connecting a decent power supply to it (better yet, connect an AC/DC power supply for example from an old router, switch, portable CD player etc. (anything from 5v to 17v will do)
If you haven't already try unplugging everything , remove the chip and Bluetooth . Then reinsert them and apply power agian.
The only thing that kinda changed was when the comm ports are defined, instead of using the lower numbered port to connect to the EZ-B, use the higher number instead. Other than that there were no major changes or differences in the bluetooth application.
If your bluetooth unit is actually turning off, when a connection is attempted then it may be a defective unit.
