Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Having Trouble With Projects That Have Custom Ezbits?
Are you having trouble loading your projects with custom EZBits since the 6-5(6?)-13 update?
Well I did so I figured I'd show you all how to save your projects from complete disaster.
Step 1. Make a copy of your project.
Step 2. Open the project in Notepad (or whatever)
Step 3. Remove EZ Bits from the project. Here is what one looks like. The key is to make sure you have your matches
 [EZRobotBit] code here [/EZRobotBit]
NOTICE I had to change all of the tags from greater/less than to brackets so it would let me post this.
There are two in this example. Can you find them?
 [EZRobotBit]  #START EZBit
        [GUID]59bc6bd3-9043-42de-bace-79a349468e06[/GUID]
        [Transform3D]
          [Matrix]
            [M11]1[/M11]
            [M12]0[/M12]
            [M13]0[/M13]
            [M14]0[/M14]
            [M21]0[/M21]
            [M22]1[/M22]
            [M23]0[/M23]
            [M24]0[/M24]
            [M31]0[/M31]
            [M32]0[/M32]
            [M33]1[/M33]
            [M34]0[/M34]
            [OffsetX]-8.2720588235294326[/OffsetX]
            [OffsetY]-14.446227929374004[/OffsetY]
            [OffsetZ]0[/OffsetZ]
            [M44]1[/M44]
          [/Matrix]
        [/Transform3D]
        [CategoryId]1[/CategoryId]
        [Connections]
          [EZRobotBitConnection]
            [GUID]c9c2960a-9fd9-41a9-b812-f81613f80a19[/GUID]
            [Description]Left Wheel (Modified)[/Description]
            [BitConnectionType]Servo[/BitConnectionType]
            [Port]D13[/Port]
          [/EZRobotBitConnection]
            [GUID]92f3c04f-b254-41d8-bd73-6c7307e77bb1[/GUID]
            [Description]Right Wheel (Modified)[/Description]
            [Port]D11[/Port]
        [/Connections]
        [Description]Bottom half[/Description]
      [/EZRobotBit]  #END EZBit
        [GUID]fee55075-b6d8-4a2c-809b-22cb7e49abbe[/GUID]
        [Transform3D]
          [Matrix]
            [M11]-2.2204460492503131E-16[/M11]
            [M12]0[/M12]
            [M13]1[/M13]
            [M14]0[/M14]
            [M21]-1[/M21]
            [M22]-2.2204460492503131E-16[/M22]
            [M23]-2.2204460492503131E-16[/M23]
            [M24]0[/M24]
            [M31]2.2204460492503131E-16[/M31]
            [M32]-1[/M32]
            [M33]0[/M33]
            [M34]0[/M34]
            [OffsetX]-10.202205882353452[/OffsetX]
            [OffsetY]4.89566613162121[/OffsetY]
            [OffsetZ]58.83053713058257[/OffsetZ]
            [M44]1[/M44]
          [/Matrix]
        [/Transform3D]
        [Connections]
            [GUID]fcd53845-419a-43e5-97bc-f76588cc499e[/GUID]
            [Description]Left Arm[/Description]
            [Port]D5[/Port]
            [GUID]28c0cdc1-8849-41c7-af39-73f03bb98b55[/GUID]
            [Description]Right Arm[/Description]
            [Port]D7[/Port]
            [GUID]3b8b001a-7351-498d-b65d-2df00c7495eb[/GUID]
            [Description]Cam Tilt[/Description]
            [Port]D0[/Port]
            [GUID]06fd5272-8bdf-45ed-a3c0-2c25662de0d2[/GUID]
            [Description]Cam Pan[/Description]
            [Port]D2[/Port]
        [/Connections]
        [Description]Top half[/Description]
As you can see the sizes vary depending on what's in them so be sure to check your tags. You don't want to delete anything you are trying to save.
Sure, you'll have to re-make re-import your stls and make new bits but, at least all of your other hard work won't go down the tubes. Besides I'm having fun importing stls. (@DJ Thanks for the servo btw!)
I hope this helps someone out.
I wish I had thought about 3D printing when I was doing the first 4 attempts on Melvin's arms!..
Omni bits will come in handy there, well provided on which bits of course...
Lol. I want to 3d print new arms for Jarvis that are 50 Percent longer so dude can reach stuff lol. Right now he's kinda like the Trex of medium sized robots.
Get playing with Sketchup or AutoDesk 123:) I think 3D printed arms for Melvin are going to be the only solution that meets my standards... Can't wait for the 3D scan feature to be available. I think I just convinced myself to save and buy a 3D printer:D
Just thought I'd mention that I had problems with the Sketchup exports but 123D Design worked just fine as far as exports.
I found Sketchup was easier to use and it's less of a resource hog than 123. It also required a plugin to do the stl exports so maybe the pluging is at fault.
But 123 is pretty cool once you get familiar with it. It is a resource I didn't feel like trouble shooting the Sketchup issue so I've just stuck with 123.
123 tip:? It seems that 123 always starts and loads files using mm for measurements. My fellow Americans, you may want to get in the habit of setting it to inches as the first thing you do when you start the program and/or load a file.
Personally speaking I prefer 123. I have AutoCAD, Inventor and SketchUp but I always go back to 123. It makes it very simple although it's not as advanced but it's a good tradeoff.
I have problems with STL exports though. It's probably me but if you look at the one I've zipped up and attached it should have the 3 wires for the servo cable shown and the servo spindle but importing into ARC these aren't shown... Any ideas?
TowerProMG90MicroServo.zip (STL and 123 formats)
I'm at a loss my friend. It only imported one wire for me. I started deleting wires one at a time then all of them, once I did that it only showed the spindle. Then the main body. SO, my only option was to make it an ezbit.
https://alpha7.netau.net/ezr/Mg90MicroServo.zip
I hope that will get you by until this gets figured out. It seems to not register as one complete piece even after grouping them. I tried "inserting" it hoping it would convert it to 1 generic object but that didn't happen. I've only scratch made a couple of boxes with 1/16" walls. Started with my solid shape, drew the rectangle and recessed it in. I haven't tried putting pieces together yet.:(
#15
I'll figure it out. it may be because I haven't combined (not group) all of the primitives, since doing so loses the separate materials (which doesn't matter but I like it to look right)
Just play dude, you'll figure it out and figure out the best way that works for you. I generally draw squares, rectangles and circles. Extrude them to the right heights. Draw more and extrude to remove parts that I don't want, recess bits etc. The servo I drew up (which is to scale within 0.5mm) started with a box for the bottom of the servo, another box for the piece with the mounting holes in, another box for the top part, two cylinders for the very top and spindle. Drew circles and extruded to remove for the holes and that was about it really. Then just played and added detail. And if you look inside the servo you will see I used shell to make it hollow and threw in a little "watermark" to let me know if anyone has "borrowed" it for anything:)
#16
Thanks Rich, that is the way I figured out how to do my boxes. I tried grouping the servo parts and even changed the material to the frosted glass so I noticed you had hollowed it out. I also tried combining them all but it said that nothing intersects. (I may be doing it wrong, What would be the source and target? Any links to a good Tutorial or Vid on this would be appreciated.) It still only imported one of the wires.
It was late so I didn't see the watermark. I'll look at it when I get home from school. I can't figure out how to slice an object down the center. (Like JD's head) Maybe I'll get struck with a grand idea.
Did you DL the bit? FYI it goes in folder 5. Now I'm curious to see if your mark translated over to the ez-bit. I didn't look "inside" any of the parts. Let me know if you figure it out.
