After hooking up an external 8 ohm speaker to the EZB and figuring out how to get the LED in my Robie Sr.'s mouth to flash like I wanted, everything was working great.
But then for no reason I can tell, it started doing THIS.
It sounds like maybe the speaker has just blown out, but with the way it's all wired, it would appear (to me, at least) that the LED should still be flashing with each spoken syllable like it should be.
Any thoughts?
Hi Bob,
One thing I forgot to ask is where your volume is set on the soundboard skill, 100%?
As others have mentioned you could have a minor bridged connection, all you would need to do is check with a multimeter (ohms setting) and see what the resistance is between the speaker connections. If the reading is low (lower than 8ohms with the speaker connected or lower than 40kohms without) than you may need to add some flux and reflow your connections. Reflow would also help you see if a trace/pad comes off the board but I'm fairly certain this isn't the case.
I don't see WiFi as the issue unless you are encountering other issues when using the digital ports, servos, etc.
I also don't see a broken wire as the issue, no sound would come out in this case.
The OP said it worked properly the day before. That's why I started thinking it could be on the computer, router or Wifi end. If the OP damaged the EZB while soldering I would think the issue would have showed up right away.
I like your idea of checking and playing with the volume slider on the Soundboard control in ARC. His video shows a rhythm to a voice cutting out. Almost like clipping.
"can you desolder the wire and solder the other direction?" Not very confidently. I can't see what you're suggesting with that pic.
"One thing I forgot to ask is where your volume is set on the soundboard skill, 100%?" It was at 100%, yes.
"As others have mentioned you could have a minor bridged connection, all you would need to do is check with a multimeter (ohms setting) and see what the resistance is between the speaker connections. If the reading is low (lower than 8ohms with the speaker connected or lower than 40kohms without) than you may need to add some flux and reflow your connections. Reflow would also help you see if a trace/pad comes off the board but I'm fairly certain this isn't the case." I have no idea what you're telling me here.
"That's why I started thinking it could be on the computer, router or Wifi end." I don't think it's the computer, otherwise the the test phrase I have in the Speech Synthesis control would be equally glitched when talking through the PC Speaker instead of the EZB (right?). I can't think the router or wifi are at fault, because every other control is working fine without issue.
"I like your idea of checking and playing with the volume slider on the Soundboard control in ARC." Oh, was that being suggested earlier? No, that's not it either. The EZB's start-up noise is just as quiet as soon as the battery's plugged in.
Do you still have all those LED's strung together that didn't work the way you thought they would. Or did you remove them and are just using one LED?
I did notice that the LED is now not flashing like the first day it was working. This is a good clue. What changed? Is the LED now burned out? This would cause problems.
Any chance you could post a pic of your wiring of this circuit?
You may have to pull everything out of the robot and bench test this again to get it right. At the least it may make it easier to repair or see your issue. You may have to rebuild the circuit with new components and make sure it's wired correctly.
Good luck and try to enjoy the learning process.
Are you connected to the EZB through AP mode or client mode? Meaning, do you have the EZB connecting to your router?
@Dave Any videos you'd recommend on flux & reflow? Again, NO IDEA what I'm looking at here, so searching for "adding flux & reflow" on youtube isn't doing anything for me.
I still have all of the LEDs in the original circuit as I configured them, yes. It was working and I didn't want to mess with a good thing. But what changed? I don't know, it just stopped. And unfortunately, I can't show you a pic of how the wiring originally was. It was suggested that I don't use the makeshift splitter that I made (which WAS working, until it wasn't), and that I wire the speaker directly to the EZB and the LED directly to the speaker, so that original wiring that I made is gone. At the moment, the best I have of my original set-up is that graphic I made at the beginning.
@DJ Sures I don't know if I'm on AP or client mode. But regardless, every other control is still working perfectly fine and the internal EZB speaker is having those issues without being connected.
I'm no expert on all this but here is what I've learned:
Reflowing a solder joint (not to be confused with reflow soldering) is simply heating up the solder joint to re melt the existing solder and letting it cool back down. This will sometimes renew the joint and ensure a good and strong and clean connection. This is done when a solder joint (soldering a wire into a hols for example) has been improperly soldered with not enough heat, a dirty soldering hole, pad or wire or the joint has been stressed with use (heat). It's sometime referred to as a "Cold Solder Joint". Adding a little flux to the joint you want to reflow helps transfer the heat from the iron and help protect the board and traces from overheating and damage. It also helps remove any contaminants that would cause the joint to be less conductive.
Search for "reflowing a cold solder joint" for more videos. Here's one I found:
