EZ-Script Console icon EZ-Script Console — Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN. Try it →
#baloo
Don't know if you can 'mix n match' the if and getping functions like that??
you need to test the value Getping returns with an if statement afterwards. Lots easier to use ping_wait
this what i have so far see code below i what to test to see if the distance is under 15", if so turn robot to the right or left, depending on where it is looking
Servo(d14, 100)
# start for radar loop
:radar_loop
goto(full_right)
goto (haft_right)
goto(Full_Forward)
goto (haft_left)
goto(full_left)
goto (haft_left)
goto(Full_Forward)
goto (haft_right)
goto(radar_loop)
#set the servo to look left
:full_left
Servo(d14, 10)
# turn to the right start here
#code go here to turn robot right ??
#end of turn right here
return()
:haft_left
Servo(d14, 25)
return()
:Full_Forward
Servo(d14, 50)
return()
:haft_right
Servo(d14, 75)
return()
:full_right
Servo(d14, 100)
return()
sounds like you want to use the radar control?
hi DJ my own radar ? so how do i use getping(d13,d12) in an if statment .. if possible
hi dj i am doing it this way just to learn about some of the script command you have showen on the help page
The most powerful commands for something like this are the WAIT commands. For example...
:Start
# Wait for ping sensor to return a value less than 15
Ping_Wait(d0, d1, lower, 15)
# If the head servo is greater than position 40, turn right
if (Servo(d5) > 40)
  Right()
# If the head servo is greater than position 40, turn left
if (Servo(d5) < 40)
  Left()
# Pause for 2 seconds while we move
Sleep(2000)
# Stop moving
Stop()
# Goto the start of the script
goto(Start)
And then you'll want to move the head back and forth... So create another script that does it...
# Set the servo speed on the head servo to a slow speed
ServoSpeed(D5, 4)
:Start
# Move servo head all way to the right
Servo(D5, 10)
# Pause for 7 seconds while head moves
Sleep(7000)
# Move servo head all way to the left
Servo(D5, 80)
Sleep(7000)
# Loop
goto(Start)
Hi DJ thanks for the help I broke your move script into 2 scripts I just need to fine tune the time, to get it all to run smooth:D
turn right
# If the head servo is greater than position 50, turn left
if (Servo(d5) > 50)
  Right()
Sleep(2500)
forward()
Turn left
:start
Ping_Wait(d13, d12, lower, 15)
# If the head servo is less than position 50, turn left
if (Servo(d14) < 50)
Left()
Sleep(2500)
forward()
goto(Start)
and your scan to
Servo(d14, 80)
ServoSpeed(D14, 1)
:start
Servo(D14, 20)
Sleep(800)
Servo(D14, 80)
Sleep(800)
# Loop
goto(Start)
Nice:) It'll use a lot more processing to hav two scripts for movement. How come you separated them?
