hi all I am writing my own radar script
how do i use the value return by getping(d13,d12) e.g. :loop tr if getping(d13,d12) < 20 then Right(200) goto(tr) else stop script and exit
Speech Synthesis Settings
— Configure Windows Audio.say()/Audio.sayEZB() TTS on EZB#0: voice, emphasis, rate, volume, speed/stretch and audio effects; copy control script.
#baloo
Don't know if you can 'mix n match' the if and getping functions like that??
you need to test the value Getping returns with an if statement afterwards. Lots easier to use ping_wait
this what i have so far see code below i what to test to see if the distance is under 15", if so turn robot to the right or left, depending on where it is looking
sounds like you want to use the radar control?
hi DJ my own radar ? so how do i use getping(d13,d12) in an if statment .. if possible
hi dj i am doing it this way just to learn about some of the script command you have showen on the help page
The most powerful commands for something like this are the WAIT commands. For example...
And then you'll want to move the head back and forth... So create another script that does it...
Hi DJ thanks for the help I broke your move script into 2 scripts I just need to fine tune the time, to get it all to run smooth:D
turn right
Turn left
and your scan to
Nice
It'll use a lot more processing to hav two scripts for movement. How come you separated them?
