NMS Navigation Data Grabber icon NMS Navigation Data Grabber — Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan. Try it →
OK, stupid question. How do you remove the wheel assembly from the wheelchair. If it was off of the wheelchair , I could get to things better. I will have the picture sometimes soon.
As Toymaker referenced, i'm using encoders to get my kangaroo to work with the kangaroo from dimension engineering. Currently, i'm not sure that the ones I installed will work. The size of the jazzy motor shaft has been a tremendous challenge to overcome when installing (non-standard) wheels and inexpensive encoders. For example, I just dropped off my 10" wheels and $40 ea. custom 17mm hubs to a machine shop to get them to make them fit. I am currently unsure what size encoders would be necessary to work but I am convinced that coupled with the kangaroo, the rover will be very accurate and safe which is imperative for this size bot.
As for removing from the wheelchair, I don't know the answer to that but they must attach via the allen screws. Take note, all of the allen screws on the motor case are of different lengths so don't over tighten before you are sure where they go. Also, many WC motors have a lever that puts them in neutral, mine are black and about 1.5" tall, rotate them 45 degrees one way and they engage, the other way they disengage.
Sorry it took so long to post. Here is a pix of the model I need to take the motors off to remove the brake.
Thanks!
Yes you will have to remove them from the chair unfortunately. The side of the motor you need to get too are butted right up against each other separated by what looks like a piece of metal. That end has a black plastic cup attached with a zip tie around the circumference. Once you get inside I believe there is a nut that needs to be removed. Not home right now but will check on mine to let you know further. Im using these exact motors for the shoulder up/down joints on my bot. Will login later to check back. Chris
Saved! I cut the wires only and tested the motors and they are running fine. I did not have to pull all of that stuff off. (Praise God!).
