Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
Fix Control Icon Positions On ARC Desktop?
Is there any way to assure that the control icons will maintain their positions if a new control is added or ARC is exited, then reentered?
I have 12 AX-12 Vertical servo Controls arranged in numerical order. I am using them to fine tune servo positions.
If I add another control, or exit then later reenter ARC, Smart Arrange has it's way with my carefully positioned icons.
Thank you.
DJ,
Thank you, thank you, thank you!
I knew there had to be a way. I forgot about the Auto Arrange New Control check box.
