Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
Fix Control Icon Positions On ARC Desktop?
Is there any way to assure that the control icons will maintain their positions if a new control is added or ARC is exited, then reentered?
I have 12 AX-12 Vertical servo Controls arranged in numerical order. I am using them to fine tune servo positions.
If I add another control, or exit then later reenter ARC, Smart Arrange has it's way with my carefully positioned icons.
Thank you.
DJ,
Thank you, thank you, thank you!
I knew there had to be a way. I forgot about the Auto Arrange New Control check box.
