I am going to try turning off my desktop. Wish me luck!
MovieMaker
— Edited
3 Participants
EZB Connection
— Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C.
no, everything is relatively New.
OK, Everything is working as desired. My desktop can access my notebook on the robot. The robot can access the internet and can at the same time be connected to the EZB 4.
I LOVE the way it works. As it turned out there was an Explanation mark in the Network configuration. But, when it say connected, I assumed that it was working. So, I went in and did some changes to correct it (didn't really know what I was doing except changing the settings). That ONE little thing was what had me on wits ends since I got the V4.
Thank You BOTH for your help and kind patience.
Mel
Now you need to go back into ARC and use the scan tool to find the EZB that is now connected to your network... The scan tool is right beside the silver flying saucer button... It looks like a little antenna... It will scan your network for the ezb4... It will chime when it finds your ezb... Then select it and then press connect in the connection control.... It may take a few minutes to look for the ezb4... When it finds it will be a wifi address that once you select will automatically be entered into the connection control under EZB 0 (usually everyone uses the first connection, but you can use any of the 5)...
When it says "I have successfully connected to your network" it means just that (it's now part of your network like your PCs, printers or whatever devices)... You still need to connect it under ARC.... See my last post to learn how to do that...
Awesome! Glad to hear you got it working.
Yeh! if it would not have been for your support it would've taken longer. Thanks!
Wow, talk about over complicating things!..
The video tutorials provided by EZ-Robots should be clear enough and straight forward enough to follow in order to connect the EZ-B V4 to a PC and adjust the settings if required. The text and image based tutorial I posted shortly after receiving my V4 should also clearly help guide users through the process.
The multipost, complicated and difficult to follow topic could have been easily solved. The desktop is connecting to the V4 network automatically because it has been told to do so. You can change this in the wireless network settings on the desktop.
Then it's purely a case of following the video tutorial provided by EZ-Robots (a reset of the EZ-B V4 may be required in some cases if settings have been changed).
Anyway, my real reason for posting here...
@Richard, you mentioned any of the 5 connections can be used however bear in mind that if the EZ-B is to be controlling the movement of the robot with a Movement Panel then it must be board 0. The Movement Panel will only work for board 0. Therefore if only one EZ-B is being used it is good practice to set it as board 0. Also, all scripting commands would require an additional board number before the port i.e. Servo(4.D0, 90) if using anything but board 0.
@Mel, it sounds like you are better off with the EZ-B V4 in Client Mode. This way; Both the notebook and the desktop can access the EZ-B if required. Both the notebook and desktop keep their internet connection. All devices are networked on the same network without the requirement of any bridging. You can even control an instance of ARC running on the notebook with another instance of ARC running on the desktop - the two instances of ARC can be linked together and controls and data shared between the two with no fuss.
I don't know if the first post has been edited or if it was always just a statement about turning off the desktop PC however it isn't really helpful and this topic will be returned to any new user searching for similar help. Perhaps it would be useful if you explained more about your set up and the problem in the first post, this way it may save other users asking the same question.
Glad you have it sorted now though and that Richard was able to guide you through it.
@Rich... I wasn't aware of the Movement Panel only working with board 0.... thanks.... I am still learning too....
Cheers....
Richard
God Bless You all!
