Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
I think it would be cool to make my own quad. The only problem I have is the motors. ESC's aren't directly compatible with ARC and I'm not sure how much work it would be to make a script to use them. Unless I use brushed motors(not sure) I'm stuck.
You control ESC just like a servo
Really?... Hmmm. So I could set up a slide script or something to control the esc's... Well if that's the case all I need is some help finding the right motors, props, and esc's and I'm ready to go! Maybe soon, but have to get another ez-b first.:D eyeroll
I will offer a DIY kit after V4 comes out. It will use axi brushless 2808 motors , 9.5 props, 12 amp escs, the 6 axis gyro board , lipo battery and frame.
How much do you think it'll cost?
EDIT: Looked at the motor price... geesss! Could you recommend something cheaper(same power)?
I forgot to ask, how much will your quad weigh? Cause that determines the motors.
#15
We don't have a weight right now, when we do we will post it.
