TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Ez-b Soundboard
Ez-B Soundboard
I seem to be having some trouble with the ends of sound files being cut off when played via the EZB Soundboard. Doesn't happen every time though. I have my files playing out through the un-amplified terminal on the EZB, through an external amplifier to a larger speaker. Has anybody else had this issue? I did try adding a couple of seconds silence to the end of the files in the program "Audacity" which does seem fix the problem but that doesn't explain why the problem exists in the first place. Any Thoughts?
Steve
#33
  1. load ARC
  2. start a new blank project
  3. connect ARC to your robot
  4. add the Bench Mark Utility
  5. Leave the value of 30 in the benchmark utility and press the READ ADC button
  6. Write down the number that it presents (X Number Pr Second)
  7. Now click on the CONNECTION Control GEAR to open the settings
  8. Change the EZ-B Board #1 Throttle Setting to a 1
  9. Go to #6 and repeat
Here's a link to the benchmark utility manual page: https://synthiam.com/Tutorials/Help.aspx?id=144
There are question marks to assist. Hover your mouse over the question mark in the connection control settings of the flood control to find out what it is does.
