need a small itx computer board with usb inputs running EZB software if a smaller design robot ?
yes,there is no usb port on EZB,ITS a microcontroller does not having a operating system like windows installed, other way you can do it is buy a bluetooth webcam or wifi,problem is using a webcam it needs windows drivers installed on bluetooth or WIFI it transmitt signal to a computer with drivers installed on a operating system and you see it on your PC the video
there is the ROBOBOARD can can install windows or rabbit board,both are small,but like all boards you need memory stick or hard drive,there is a tiny LINUX BOARD ALSO
there another way but very hard to hack a USB webcam and find the TTL PORT going to the USB chip and tie a bluetooth transmitter to it,never tried it but might work
hi thomas,have you started to use the EZB YET
You can used a wifi cam like this...
Or just put a computer inside your bot , a 6.5 inch mini itx....
@JSTARNE is not the bluetooth that EZ robot sells lot of my robot designs use a itx-board ,but smaller robots need a bluetooth like in DJ wall-e project
Yea , I gotta controll any other robots with Bluetooth , its too much money to put a itx in each one lol.
