Anyone tried these ESC's from Banebots?
rgordon
— Edited
Camera Click Servo
— Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support.
rgordon: If you could have connected many of these esc the board ez-b, are controlled by PWM with a standard servo control from ARC and can be used when the ESC have reverse gear or have the two directions of rotation, the central position of the servo position that does not act the ESC (approximately) I have disconnected the red wire connector that goes to the ez-b, is recommended because the ESC has a BEC that supplies 5v when connected to radicontrol receptors, such as ez-b has its own supply voltage does not need the red wire . Greetings.
This might help, it's a little bit dated since all the updates but it might helpLink
Thanks! That helps a lot
