Anyone tried these ESC's from Banebots?
rgordon
— Edited
EZMQTT Client
— MQTT client for ARC: connect to brokers, publish/subscribe topics, map incoming messages to variables (incl. binary arrays) and run scripts.
These are what im using https://www.ebay.com/itm/ESC-20A-Brushed-Reverse-Motor-Speed-Controller-1-16-1-18-CAR-Boat-BRAKE-OFF-/160705272506?pt=RC_Modellbau&hash=item256ac7daba esc
I have bought two esc like these very good price, with heat sink and fan, your esc have looked like a plane because it leads to external heat sink, I guess the figure is exaggerated 300A, but I think so Ahun they are the best option price amps.
ESC
@ ww321q Are you using them with the EZ Board? If so, are they working OK?
Yes, I have proven with ez-b and working properly.
I only tested them as Buster is just getting started.I tested with a 7.4 volt lipo. They seemed to work great
That's good to know. Thanks.
These Banebots
) hooked up to the EZ-Board.
ESC's are controlled with PWM. So.... I could have 20 of these (if I ever needed that many
Is this correct?
I'm thinking the ESCs like I used can be speed controlled by standard servo control panel. JW
