Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Error Loading Version: 2020.11.02.00 System.Net.Webexception: The Request Faile
This is what I get when I try to start ARC   Where am I going wrong?  It was so simple with ARC and I thought that when I purchased my first and second robots from EZ Robot that it was part of the deal.. Now I have to pay to get anything near what I could use before
System.Net.WebException: The request failed with HTTP status 403: Forbidden. at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) at ARC.com.ezrobot.www.apps.WebService.kP6ln77AuWUJJyMysjVO(Object , Object , Object ) at ARC.com.ezrobot.www.apps.WebService.GetUTCDateTime() at naZDkGAjMsBhvxZEeOq.ANNIWDA3D4g2AKlqXcE.yCiLoCq6Hq()
Thanks J D   However my question shows the error I get when I try to open ARC downloaded from the website you suggestJ     I have ARC and can not open it,  That is the problem.   This is the error I get;      Version: 2020.11.02.00
Portugal
#3   — Edited
You have Version: 2020.11.02.00 Download and install new FREE Version 2021.03.02.00
