Openai Chatgpt icon Openai Chatgpt — ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API Try it →
France
Equivalent of EZscript's  SleepRandom(a,b) for Python ?
Equivalent Of Ezscript's Sleeprandom(A,B) For Python ?
Hi, I used to use a lot SleepRandom(a,b) in my EZ-scripts to simulate random behaviors. I don't find the equivalent for Python scripting.
Outside of ARC, I use the "random" module (random module), but it does not seem to be present in ARC
import random
returns "No module named random".
Is there a way to achieve the same thing than SleepRandom with Python scripting in ARC, or is there a way to import the python random module? Thanks
Script by Synthiam
Weird that it's _random.... hmm! Random:D
import _random
random = _random.Random()
print random.random()
Thanks @DJ ! I could have searching for it forever....:D
_random works too but asfaik in Python 2 std library random exists.
@DJ: You can make it work the same way. You will need to add an additional nuget package to your ARC project:
Regarding the _random:
Quote:
It is common practice to use a leading underscore for modules implemented in C.
The other reason is too avoid duplicated import names for the same functionality: _module1 can be called from CPython (C) and a module1 (py) wrapper can coexist and internally calls _module1.
Quote:
You will find this for several modules of the standard library.
Quote:
Typically, you should use module1 and not _module1.
Note: Quoted parts/statements are copied from the internet.
That’s good to know! Thanks ptp. I seem to be learning python as we go as well:)
It seems that I cannot use any other attribute than .Random
These following attributes, part of the random module, don't work:
random.uniform(1, 10) # Random float x, 1.0 <= x < 10.0 random.randint(1, 10) # Integer from 1 to 10, endpoints included random.randrange(0, 101, 2) # Even integer from 0 to 100 random.choice('abcdefghij') # Choose a random element
For example, I tried random.Randint , _random.randint , _random.Randint. Each of them returns
'module' object has no attribute 'randint'
Is it me who is missing something... Again ?
I added this to the next update. Stay tuned
Great! Thanks a lot !
I tested rapidly the new beta version before going to work and the "random" module works great, with all the attributes (and without the "underscore":D) Thanks @DJ
