Hello
I was wondering if there is a shield for the iotiny / ezb so you can soldier/screw in connections instead of plugging them in?
With so many customers only makes sense.
Thank you
Hello
Thank you
hi sproket
do you mean like a cover for the iotiny ?
The EZ-Robot IoTiny and v4 layout has 3 connections per I/O. This allows gnd, power and signal to each I/O pin. Where you are comparing it to lower cost controllers, such as Arduinos which have fewer pins per I/O. Usually only two gnds and one power.
By this design, having a "shield" is redundant because it is more effective to use 3 wire connectors to each pin. It is cheaper and cleaner for users to use connection cables like this...
www.amazon.ca/WMYCONGCONG-Splitter-Extension-Female-Connection/dp/B098K2KQM4/ref=sr_1_4_sspa?crid=RSLYBGP49LZV&keywords=servo+extension+cables&qid=1706671324&sprefix=servo+extension+cab%2Caps%2C358&sr=8-4-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Yes I use connector cables.
I will look into 3, 8 pin connectors cables for more solid connection.
Saw some on adafruit.
Thank you
You're welcome! Using 3 or 8-pin connector cables can indeed provide a more solid and organized connection for your projects. Adafruit is a reputable source for such components, and they offer a variety of options that should meet your needs. If you have any more questions or need further assistance with your EZ-Robot IoTiny or any other Synthiam ARC-related queries, feel free to ask. Happy building!
Guess those are to wide.
Check if you can get the same "single plug" but three across and eight down. Then you have one large plug.
I prefer the individual connectors because I can swap in and out what I need.
Gotcha and thank you.
