Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
#17
JOSH you read the specs on VU meter it says you can set the voltage,vu meter measures volume of audio and apply to leds ,more the sound pressure more the leds turns on like a persons mouth.
PWM is just mostly a flasher that does only one led per pwm output,witch for eyes it works well. MOSFET works better then a transistor because is variable resistor depending on the voltage apply.
