Audio File Out EZB icon Audio File Out EZB — Stream MP3 or WAV files from your PC to the primary EZ-B speaker for robot audio playback, alerts, music, and voice clips. Try it →
two servo's new ones.
this is after disconnecting.
Please could you click "Copy" on the debug console and paste the contents?
i forgot how to do that.
EZB 0: 11/12/2014 23:09 - TCP Server stopped
EZB 1: 11/12/2014 23:09 - TCP Server stopped
EZB 2: 11/12/2014 23:09 - TCP Server stopped
EZB 3: 11/12/2014 23:09 - TCP Server stopped
EZB 4: 11/12/2014 23:09 - TCP Server stopped
11/12/2014 23:09 - TCP Server stopped 11/12/2014 23:09 - TCP Server stopped 11/12/2014 23:09 - TCP Server stopped 11/12/2014 23:09 - TCP Server stopped 11/12/2014 23:09 - TCP Server stopped 11/12/2014 23:10 - Attempting connection on 192.168.0.30:23 11/12/2014 23:10 - Connection Failed: System.TimeoutException: Er is een time-out opgetreden voor de bewerking. bij EZ_B.EZB.Connect(String hostname, Int32 baudRate) 11/12/2014 23:10 - Disconnected 11/12/2014 23:10 - Attempting connection on 192.168.0.30:23 11/12/2014 23:10 - Connected to 192.168.0.30:23 11/12/2014 23:10 - EZ-B reports EZ-B v4 OS 11/12/2014 23:10 - Welcome to EZ-B v4 Beta! 11/12/2014 23:10 - EZ-B v4 ID: 53-54-0-0-47-255-59-60-60-38-38-38 11/12/2014 23:10 - Connected 11/12/2014 23:10 - Setting battery monitor voltage: 6.6 11/12/2014 23:10 - Setting battery protection: True 11/12/2014 23:10 - Setting i2c rate: 100000
So obviously some timeout issue somewhere confused On the second screenshot, there appears to be something like this:
8bytesToExpect: 2
Received:
- Disconnected
Is that no longer appearing in the debug console when it disconnects?
EDIT: Those two question marks were tone bars, looks like they were stripped out when I posted... should've expected that :)
it just crach ARC.i also dont see by open ARC the follow building, tutorial.no i dont see the ? marks
It might be nothing, I just noticed this from your second photo:
Are you able to upload your EZB project file? I'm on v3 but happy to try loading it on my PC if that's any help?
Trinidad/Tobago
Twitter YouTube
#15
hey nomad, I realised you have your ezb connected to you network in client mode.
do you have the same problem in AP mode when you directly connect to the ezb?
Try pushing the reset button on the ez-b and let us know what happens.
vgosine it says resseting and led turn blue.its normal goes thru android phone, but i cant get on the web server 192.168.1.1
