Is the EZ-b v4 module compatible with the Devantech 8 Channel 16A USB Relay Module?
Thanks Jeff
Pandorabots
— Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots
Thanks Jeff
EZB V4:
Devantech 8 Channel 16A USB Relay Module:
Maybe I'm missing something but the product uses an USB port.
How do you plan to connect to EZB V4 without USB ?
Maybe you mean "how do you connect ARC to the Daventech 8 channel 16a USB relay board"?
If so, that's easy... Based on the documentation manual, you merely have to send a command to turn on or off the relay. Here's the manual: https://www.robot-electronics.co.uk/htm/usb_rly16tech.htm
Create a function in your script like this...
