Community Robot Questions Devantech 8 Channel 16A USB Relay Module jst20 USA Asked Apr 2020 2 Participants ptp DJ Sures Devantech 8 Channel 16A USB Relay Module ARC Skip to comments Jump to end Is the EZ-b v4 module compatible with the Devantech 8 Channel 16A USB Relay Module? Thanks Jeff Quote Related Hardware (view all EZB hardware) EZ-B V4 by EZ-Robot EZ-B v4 with Synthiam ARCx controls servos, sensors, camera and audio over Wi-Fi or USB serial, no firmware needed. Wi-Fi / USB Servos 24 Camera Audio UART 3 I2C ADC 8 Digital 24 Jump to end Upgrade to ARC Pro Elevate your robot's capabilities to the next level with Synthiam ARC Pro, unlocking a world of possibilities in robot programming. Compare Pro Features View Subscription Plans ptp PRO USA #1 Apr 2020 — Edited Apr 2020 EZB V4: Devantech 8 Channel 16A USB Relay Module: Maybe I'm missing something but the product uses an USB port. How do you plan to connect to EZB V4 without USB ? Reply Quote Share DJ Sures PRO Synthiam #2 Apr 2020 — Edited Apr 2020 Maybe you mean "how do you connect ARC to the Daventech 8 channel 16a USB relay board"? If so, that's easy... Based on the documentation manual, you merely have to send a command to turn on or off the relay. Here's the manual: https://www.robot-electronics.co.uk/htm/usb_rly16tech.htm Create a function in your script like this... function setRelay(relayNumber, trueOrFalse) { COM.open("COM1", 19200); if (trueOrFalse) COM.write("COM1", 100 + relayNumber); else COM.close("COM1", 110 + relayNumber ); COM.close("COM1"); } // Turn relay 1 on setRelay(1, true); // pause for 5 seconds sleep(5000); // Turn relay 1 off setRelay(1, false); Reply Quote Share Login to post a comment
EZB V4:
