ADC Value icon ADC Value — Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval. Try it →
It’s quite easy. You don’t have to run an exec or any scripting like that.
Simply set your secondary display to be "extended desktop" in windows display settings
Then set ARC to "not maximized". So the program looks like a window that you can move around. Then drag and position the ARC window so it spans both monitors across the extended desktop
Now place your controls anywhere you need. This means placing your video player on one desktop and drag it to fill the screen. You’ll have to unselect "auto arrange controls" in the add control menu.
That’s all it takes. Everything saves with your project.
Thanks. The extended display will do what I want
