Screen Recorder icon Screen Recorder — Record your screen to WMV1/WMV2/H263P files with selectable bitrate, save-folder and start/stop controls, creating tutorial or demo video snippets. Try it →
Control Ezb From Mobile
Hi I would like to know if it s possible to use app mobile to control ezb from my iphone without using wifi.? I would like to use web browser( app mobile) from my iphone to launch camera. I found a tutorial to do that from my ipad or iphone but the phone have to be connected to the ezb by wifi. Is it possible to do that without using the wifi and use directly the box to access to the ezb. Is it clear? If it s possible, does it exist a tutorial? Christophe
Hi CochranRobotics First thank you for your reply and your help. i understand the client mode and the Toolsto find the suitable IP address but when i m on the iPhone app and when i try to scan an IP trere is no IP adress. Is it possiblle to define an IP fix to avoid it to scan and be faster ? Does ezb have a specific range of IP address because, the scan doesn't it find the ip on the network. ( when the ezb has connected to the network in client mode, he said " i have succeeded connected to the network") My ezb is EZB V4
topic read : https://synthiam.com/Community/Questions/10249 https://synthiam.com/Community/Tutorials/92/1 https://synthiam.com/Community/Questions/5901 https://synthiam.com/Community/Tutorials/102/1 for this tutorial ".....102/1" im stopped to the step 'IP finder'. The P finder doesn't find ip of the ezb....
When i read all the topics, i'm wondering if someone have ever could connected in client mode.... but i guess than yes confused
I used too a program "Angry IP scanner" and i get the same result.
last think, in the app iPhone, when i scan the ip address. i have the following message : "listening for EZ-BV4 x/2 devices". To access by this way, you don't need to have this update...?
Christophe
There is no need to have the x/2 update to use the EZ-B V4 on a network.
As to assigning a specific IP address to the EZ-B, you can do this through your router by assigning it to a static DHCP address. How to do this depends on your router/dhcp server. You would be able to find the device in your DHCP leases and then assign it as a static DHCP lease. Your DHCP section of your router should also show you the IP address.
The EZB scans the 4th octet of the network that your computer has for its IP address. For example, if your computer has an ip address of 192.168.1.100, the scanner will start at 192.168.1.0 and go to 192.168.1.255. You can change the scan to start at a different IP address and go through an specified stop range.
The benefit to the x/2 upgrade is that the EZ-B will broadcast its ip address and it will show up in the box that you had mentioned. This prevents you from having to scan for the IP address.
If you can let me know what router you use, I can search online for the documention for that router and let you know where to look for the IP address. I think what is happening is that the DHCP scope is outside of the range stated above. For example, your pc is on say 192.168.1.100 and your DHCP scope is at 192.168.0.0 through 192.168.0.254.
Thanks David
Hi David it will be nice to have your help. I use free box to connect ezb to my PC. i found the document about the IP address but i need to know the MAC address of the EZB..
Christophe confused
David you are very nice with me i just need how to find the mac adresse of my ezb. Christophe
You should be able to see the mac address in the DHCP leases section of the router. it will look something like two digits then : then two digits the : repeating about 10 times or so.
I don't remember if it is possible to see the mac address from the EZ-B's webpage by connecting directly to the EZ-B or not but I don't think it was visible. The best place to look would be in the DHCP leases list on the router.
"DHCP Clients list" may be what they call the DHCP Leases section. I have been looking through their usergroup discussions to try to find screenshots but haven't found any yet.
