Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Contest :) Help Identifying A Replacement Capacitor
I have a DC to DC converter but a cap is torn off and is too damaged to solder. There are no legs to solder to. Anyways find me a economical replacement , and you get 2 higher torque 385 mabuchi 6 to 12v motors , excellent replacements for the rad robot with longer body but same diameter shaft. Shipping outside the USA you pay for. Okie dokie! Post where I can buy it in the USA from a store. Ebay does not count. Post the specs as you read them too:)
Don't forget I need to get a replacement... So where do I get that. First to link with a suitable replacement?
Hi Josh Its a surface mount correct? here $2.50 Amazon
Yes it is. I need to be able to solder the replacement to the surface of this PCB. You can see clearly on the right where it goes.
I would also get a 22uf then a size comparison would help confirm. The pics they show are all the 10uf version looks like so ignore that. See my previous post
I wonder why they don't show the same identifier numbers on the top of the cap?
That's a manufacturer type identifier if its aluminum foil package or temp rating, tolerance. I believe the S is surface mount and V might be anti vibration. It all depends on the manufacturer its more Panasonic than anything else and probably got lead used in construction so old? The make of the converter might give a clue but generally they have very wide tolerances and size is the determining factor for capacity using the same construction. Its definitely 2.2uf or 22uf and 35v which for your application is all you really need to know. I will ask a real expert tomorrow and see what he says if you like. Off to bed now
#15
OK I'm seeing 22uf is not right based the decoder troy Posted which may explain why the code on that cap you posted doesn't match. Try again? Remember Mel you gotta post Where I can buy it:p
#16
You might be able to find it at Digi Key. I have used them for work and home. The website is a bit of a pain but fast delivery and fair price. Digi Key
