Hitachi-LG LDS Lidar icon Hitachi-LG LDS Lidar — Hitachi-LG LDS 360-degree LiDAR driver streaming scans into ARC NMS for obstacle detection, SLAM use, Arduino hookup, config options and variables. Try it →
I would assume it's a resolution issue since the configure button is there on my ARC (from memory, I haven't opened it since I'm not at home but am 100% sure I have added modified servos in the latest release).
If possible can you post a screenshot? (Press Print Screen, open Paint, Paste, Save as Jpeg, Attach the file to your reply). What is your screen resolution? What OS are you using? etc. (Basically give as much info as possible about your system).
Try deleting the modified servo and then reinstall it. I added 2 servos and did not have any trouble.
I have win xp, can't find what my resolution is, and the little logo in the config button has a gear-looking circle.
Keep in mind the newest release of EZ-B does not support XP
@Tony, that is correct. Click on the button and the config should pop up.
@pjdatechy, just so you know, the XP issues are few and are not going to be the cause of a config button not showing. Mainly the unsupported features for XP are the camera control (however it works in XP but not Vista) and voice recognition (which works in Vista but not XP). Other than that it should run OK.
The little gear is your conf button
