Hello,
I recently purchased a camera for my EZ-B v4 controller, but I'm having trouble connecting to it. Every time I try to connect this error message displays repeatedly:
Camera Initialized: EZB://10.0.0.56:24 @ 320x240
ezbv4 camera image render error: System.ArgumentException: Parameter is not valid.
at System.Drawing.Bitmap..ctor(Stream stream)
at EZ_B.Camera.aJo6NxZbaD(Byte[] )
at EZ_B.EZBv4Video.o4twmdwIUb(EZTaskScheduler , Int32 , Object )
I'm connecting to the camera in Client mode and have made sure I'm including the proper port number as suggested in this post. I've also tried re-seating the board and the camera cable as suggested in this post. I'm not really sure what else to do, or what I may be doing wrong. Is there something that I am missing?
Shut the antivirus off try that can't hurt This just help someone else EzAng
@Nomad: Yes I am. Here are some pictures of how I have it connected
@EzAng: Thanks for replying, but turning off Windows antivirus protection didnt help me :/
magnefying your picture.i see some strange stuff.
Aw man, I'm not really sure what its supposed to look like but heres a closer up picture if that helps you inspect it. Do you recommend that I purchase another camera?
how old is the camera?
you can pull in and out the cable on the camera side a few times.
it seems like pin nm 4 is od.
I just purchased the camera in July and it has been this way since I received it :/. What did you mean by "you can pull in and out the cable on the camera side a few times"?
pull out the camera cable on the camera side in and out the socket a few times.
question.do you live nearby the sea or big lake ?
