Semoic Range Sensor Module 10-180Cm Distance Sensor Tof10120 Distance Sensor
anyone heard of this?
Here is the info on this unit: https://dronebotworkshop.com/laser-vs-ultrasonic-distance-sensor-tests/
Audiotoolbox Plugin
— Enable UWP voices, change default audio devices, capture audio and route it to EZB controllers with session tracking and device control.
Nope, hadn't heard of it until you mentioned it. I'm guessing it has an STmicro Time-of-fight sensor inside.
https://www.st.com/en/imaging-and-photonics-solutions/vl53l0x.html
It seems a re-brand maybe a different pcb with the MTOF171000C0 sharp sensor: https://www.mouser.com/ProductDetail/Sharp-Microelectronics/MTOF171000C0?qs=byeeYqUIh0OTZ%2FjsWS07tw%3D%3D
https://github.com/sharpsensoruser/sharp-sensor-demos/wiki/Application-Guide-for-Sharp-MTOF171000C0-Time-of-Flight-Sensor-Module:
Great digging @ptp, you found the one!
I'm definitely interested in this sensor.
I had never seen the sensor before. But I did think it was rather good test the gentlemen did from DroneBotWorkshop (which I had also somehow never heard of or seen before).
What is your main interest in the sensor EZang60? Is it the small size? Did you have a specific application use in mind or just general robotic? At first I thought this sensor might make for a good short range sensor for robot claws/hands, but in my mind I think IR sensors probably still work well after seeing the whole test video.
Yes, I like the size
I guess I meant to ask is the small size for the sensor desired because you have a small robot or tiny flying drone or need a sensor in a robot claw where other sensors don't work as well?
The Dimensions of the Tof10120 are listed as: 10mm x 12mm x 3.5 mm The HC-SR04 Sonar sensor has the dimensions listed as: 45mm x 20mm x 15mm
The LaserPING from Parallax Inc which is pin compatible with the sonar unit and software compatible in ez-ARC using the 1pin setting and has the PCB dimensions of: 22mm x 16mm Just wanted to toss the LaserPING in the mix for a smaller alternative. As I'm about add a camera in my tiny Wall.e I'm going to see if I can squeeze a LaserPING in there too.
Good find on this sensor. I started a thread awhile back touching on these type of sensors:
https://synthiam.com/Community/Questions/Discussing-TOF-cameras-for-robot-vision-and-navigation-18561
Regarding the LaserPing https://www.parallax.com/product/28041: Is a different product is based on RFD77402: https://www.mouser.com/publicrelations_rfdigital_rfd77402_simblee_tof_2017final/ They are gone, Heptagon aquired RF Digital (RF Digital, Simblee) https://www.businesswire.com/news/home/20160608005868/en/Heptagon-Announces-Acquisition-RF-Digital-Corporation and then AMS (e.g. digital encoders sensors used by Dynamixel) gets both (https://ams.com/-/24-01-2017-ams-announces-completion-of-transaction-to-acquire-heptagon-and-related-capital-increase) and then shutdowns Heptagon, RF Digital, Simblee (RFDuino)
Parallax has stock... maybe they will deprecate the product like sparkfun's https://www.sparkfun.com/products/14539.
