TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
Israel
ARC For Ar Drone 2.0
hey, I am a student for mechanical engeneering and mechatronics. My final project is relate to AR drone. I want to ask if this software can be interface to AR DRONE 2.0 or only to the 1 version. thanks a lot, esh
As Josh (@jstarne1) pointed out, they changed the protocol/encoding of the camera on the 2.0 which is why it is not 100% supported. The controls themselves apparently work for the 2.0 but you cannot connect to the camera of the 2.0
Israel
For the project we need the camera. I will tell you what we going to do and say me what you think. As a part of landing system , we want to develope acurrate landing system which based on vision. does the ARC can help me?
If you need the camera then you need the AR Drone 1.0 or you need to mount a different camera as has been explained previously.
Israel
According to your understanding, the project can be applied with ar drone 1 and the ARC? we dont want to spend money in stuff which we dont can to use it.. thanks
It will come down to the vision aspect. ARC has various tracking abilities in the camera control, if one of these tracking abilities will do what you plan then yes.
Download ARC, it's free. Take a look at what controls and options there are and decide if it does what you require it to do.
Israel
thank you for you Patience. did the software controlled on the vertical camera?
