Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Nigeria
ARC Connection to EZ-B v4 controller
ARC Connection To EZ-B V4 Controller
The Controller of the revolution JD robot that I purchased some months ago developed a fault and as a result a new Ez-b v4 controller was purchased. However, after setting up the new controller, my ARC would not connect although my computer is connected to the wifi of the controller. The ARC keeps popping an error that "this is not an Ez-b device" each time I initiate connection from the ARC. Here's the error code :
EZB 0:
EZB 1:
EZB 2:
EZB 3:
EZB 4:
Windows version: Microsoft Windows NT 10.0.17134.0 Screen Resolution: 1366x768 (96x96 dpi)
EZ-Builder Version: 2019.05.08.00
Attempting connection on 192.168.1.1:23
Connected to 192.168.1.1:23
Reports 69
Connection Failed: System.Exception: This device is not an EZ-B. Please follow the online tutorials on the EZ-Robot website.
at EZ_B.EZB.IHHQ23cvDe()
at EZ_B.EZB.Connect(String hostname, Int32 baudRate)
Disconnected
Reports 69
Disconnected
Reports 69
Disconnected
Also, I have reset the controller's WiFi too but to no avail. Can you help with any technical assistance to resolve this issue?
#9   — Edited
Please use EZ-Robot's website for support of their products as this isn't EZ-Robot's website. Specifically, I think you're looking for this tutorial from their product tutorial: https://synthiam.com/Community/Tutorials/15?courseId=4
PS, do not disable windows defender ever. That's not something I'd ever suggest:)
*Do not double post. Thanks!
#11   — Edited
Hi...in my build also i have a lot of confusion about this connection. I would like to understand how the actual network config works. I can log into my home network over VPN. I presume I could access the bot through this? Is the video compressed enough that I can view it over the internet?
circuit card assembly
hi basilvines
is this tutorial you are lookin for ?
This is a good tutorial but only works with EZB software. The ARC software doe not have the cog in the connection window to allow wifi access to the JD robot for renaming. I have a class of students and the list of EZB robots is too confusing unless they have unique names. Where can I find access to wifi on the JD in the ARC software?
#15
You can alternately type 192.168.1.1 into a browser window when connected via AP mode.
