Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
Possibly A Daft Question
As many of you will (painfully) know I am learning loads and asking lots of questions, I would apologise, but if you don't ask you may never really know. So here goes another question.
Whilst looking into servo speeds in the ez script help i noticed something wierd and was wondering if I am missing something.
ServoSpeed (servoPort, speed) Set the speed of servo or PWM. This is the speed to move between positions. The servo speed is a number between 0 (fastest) and 10 (slowest) *Note: If the ServoSpeed command is being used in an initialization script, ensure the servo positions are set first. This is because with ServoSpeed, it moves from a position, to a position, at the specified speed. If there is no previous position (such as during power-on), the software assumes the position is 0. Example: ServoSpeed(D14, 25)
It says that the servo speed is a number between 0 and 10, yet the example clearly gives a numeric value of 25 on port D14?
Am I miss reading this?
Confused confused
is that not 25 degrees? servo goes from 0 to 180 degrees.
I think it is a typo. The servo speed control goes from 0 to 20, but I am not sure if that equates to the same values in the script command or not. Not something I have used, and my V3 bot has been mostly disassembled since so I can't quickly test for you.
If no one answers by this weekend, I'll put it back together and try it out.
Typo;) your "daft" question found a typo! Excellent work. Goes to show, there really are no daft questions
