Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
Unknown Country
System Exception Error
Version: 2024.06.22.00
I encountered the following error message while using Synthiam ARC:
System.Exception: Speech synthesis is not supported due to an invalid operating system or missing device
   at EZ_B.SpeechSynth.StartListening()
   at ARC.Scripting.Forms.FormWaitForSpeech.OrfC5q7cmKB(Object, EventArgs)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
How can I resolve this error?
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Configure Windows Audio.say()/Audio.sayEZB() TTS on EZB#0: voice, emphasis, rate, volume, speed/stretch and audio effects; copy control script.
Microphone by Synthiam
Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback.
Speech Synthesis by Synthiam
Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable.
The error message you're encountering suggests that the speech synthesis functionality is not supported due to an invalid operating system or a missing device. Here are some steps you can take to resolve this issue:
1. Verify Operating System Compatibility
Ensure that your operating system is compatible with Synthiam ARC. The software is designed to work on Windows operating systems. If you are using a different OS, you may need to switch to a compatible version of Windows.
2. Check for Missing Devices
Ensure that all necessary hardware components, such as the EZ-B v4 controller and the microphone, are properly connected and recognized by your computer.
3. Update Drivers and Software
Make sure that all drivers for your hardware components are up to date. Additionally, ensure that you are using the latest version of Synthiam ARC. You can download the latest version from the Synthiam website.
4. Configure Audio Input and Output Devices
Ensure that your audio input (microphone) and output (speakers) devices are correctly configured in Windows. Follow these steps:
  1. Open Sound Settings:
    • Right-click on the speaker icon in the system tray.
    • Select "Open Sound settings."
  2. Set Default Devices:
    • Ensure that the correct microphone is set as the default input device.
    • Ensure that the correct speakers are set as the default output device.
  3. Test Devices:
    • Test the microphone and speakers to ensure they are working correctly.
5. Reconfigure Speech Synthesis Settings
Reconfigure the Speech Synthesis Settings in ARC to ensure they are correctly set up:
  1. Open ARC:
    • Launch Synthiam ARC.
  2. Add Speech Synthesis Settings:
    • Go to Project > Add Skill > Audio > Speech Synthesis Settings.
  3. Configure Settings:
    • Select the appropriate voice, emphasis, rate, and volume.
    • Apply any desired effects.
6. Reinstall Synthiam ARC
If the issue persists, try reinstalling Synthiam ARC:
  1. Uninstall ARC:
    • Go to Control Panel > Programs > Uninstall a program.
    • Find Synthiam ARC and uninstall it.
  2. Reinstall ARC:
    • Download the latest version from the Synthiam website.
    • Install the software and restart your computer.
7. Check for Windows Updates
Ensure that your Windows operating system is up to date:
  1. Open Windows Update:
    • Go to Settings > Update & Security > Windows Update.
  2. Check for Updates:
    • Click on "Check for updates" and install any available updates.
8. Verify .NET Framework
Ensure that the .NET Framework is installed and up to date:
  1. Open Control Panel:
    • Go to Control Panel > Programs > Turn Windows features on or off.
  2. Check .NET Framework:
    • Ensure that the .NET Framework is enabled.
Additional Resources
If you continue to experience issues, please provide more details about your setup, including the operating system version, ARC version, and any other relevant information. This will help in diagnosing the problem further.
#2   — Edited
I'm not the support crew here and don't know what all the returned info means. However one clue I'd start with is the first line that states:
Quote:
Speech Speech synthesis not supported due to an invalid operating system or missing device
What Operating system are you using and if it's Windows you should be using a recent version to be able to use all the features ARC offers. In the help section they mention Windows 7 as being sketchy to be able to run ARC. I wouldn't trust anything older then WIN 10 myself.
With that said ARC will not run in anything other then Windows.
The error message also says you may have a missing device and can't run the Speech synthesis. Is your microphone and sound section set up properly and working in Windows?
Good luck in your search and work trying to fix this.
EDIT: Athena answered while I was writing my answer. That answer sounds much better. LOL.
