Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
Servo Panel For Hitec
hi
wil there be a servo panel availeble to controle  the Hitec HS-805BB and HS-5765MH .  bolt doesn work anymore . i have power , ground averywere . servo's doesn move . they did worked before .
thanks
Persist and auto-load specified global variables between ARC sessions for consistent, personalized robot behavior and quick state restoration.
Servo Speed by Synthiam
Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
hi dj and synthiam support
okay brown out the ezb . it only happens when move the servo fast .
thank you bolt
Yeah, that would make sense. When the servo moves quickly, it draws too much current-the current drops, so the voltage drops. You can try increasing the voltage a little bit. But I think what you need is more current. OR you are trying to control too many servos and drawing too much current.
@dj
for now am using only one servo .no load . maybe i can try to slow down the servo ? or using the big voltage regulator on the chair ?
