hi anyone
when i open ARC i cant see connection number 0 ? ive looked in the settings , no luck .
Wowwee MIP Movement Panel
— UART-based EZ-B/ESP32 skill to control WowWee MIP, enabling ESP32-Cam camera support and flexible battery-powered integration.
Actually it looks like a strange bug behavior with windows. The windows at the top are all cutoff and there’s no scroll bar on the right. Load the project and press the smart arrange button. Or, move one of the lower windows to make the scroll bar come back
hi dj
when i move a window the bars are showing left and under , and the move . but stil no connection 0 .
hi dj
problem solved . by using smart arrange .
thank you
@Nomad
I've had been having this same problem for many years starting back in 2012. Just a few years ago I spent some time documenting what and when it happened in my ARC and posted here on the forum for DJ to see. Unfortunately I've looked and I can't find that post. DJ took the time to review what was happening and found the problem. He did an update for ARC that seemed to fix my problem. I haven't had it happen since that update. I truly hope this issue hasn't raised it's ugly head again.
For reference here are a couple threads about this problem I and others were having back in 2012 and 2013. Thread 1 Thread 2
Please keep us informed if this keeps happening. I'm a little worried. You shouldn't have to keep doing a Auto Arrange. This was the only solution I had until DJ's update a few years ago to fix this. I hated it when all my controls were moved around after I had them arranged like I wanted.
Another thing to check is that you have the resolution and scale in your Windows operating system set to what ARC needs. Read about this here: Screen Resolution
hi dave
thank you for the links . i will sure read them .
