Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Resolved Resolved by EzAng!
midi control returns an error
Midi Control Returns An Error
I have added the midi control. When i open configuration i have this error message. How can i fix this ?
Version: 2020.01.05.00
System.MissingMethodException: Impossibile trovare il metodo 'Void EZ_Builder.UCForms.UC.UCScriptEditInput.set_ScriptDefinition(EZ_Builder.Config.Sub.Reusable.ScriptDefinition)'. in Midi_Control.FormConfig..ctor(PluginV1 cf) in Midi_Control.FormMain.ucConfigurationButton1_Click(Object sender, EventArgs e) in C:\My Documents\SVN\Developer - Controls\Midi Control\Midi Control\FormMain.cs:riga 256 in System.Windows.Forms.Control.OnClick(EventArgs e) in System.Windows.Forms.Button.OnClick(EventArgs e) in System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) in System.Windows.Forms.Control.WndProc(Message& m) in System.Windows.Forms.ButtonBase.WndProc(Message& m) in System.Windows.Forms.Button.WndProc(Message& m) in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Midi Control by Synthiam
MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes.
Try downloading the newer version 2020.02.02.00
EzAng
Thank  you. It works with latest version.
#3   — Edited
Congratulations!
EzAng
#5   — Edited
I did post it on his site, thanks
