Vader Sentiment Analysis icon Vader Sentiment Analysis — VADER sentiment analyzer for ARC returns positive, neutral, negative percents and a compound score from text; enables emotion-driven behaviors. Try it →
Kuwait
Xamarin And Raspberry Pi
hello, so i'm planning on developing an iPad application using xamarin forms to control JD through it; and i heard to make such an application i need to use mono sdk provided in this website. i got mono sdk and i got a raspberry pi also. but how can i make xamarin code on my windows 10 communicate with raspberry pi that is connected to its own HDMI screen, keyboard, and mouse? confused
should i establish an SSH connection between them? to execute the code written on xamarin using the raspberry pi terminal?
I'm little confused with your question. Let’s break down your question so it can be addressed without confusion.
  1. Xamarin Development for Apple iOS Minimal Requirements: Apple Mac Computer, MacOS, XCode and Xamarin Tools The process is not simple and requires some time to follow all the steps.
Basically you develop an application and is deployed to an emulator, or a developer device (Requires an Apple developer certificate).
  1. Mono SDK EZ-Robot provides a mono SDK dll to communicate with EZB.
Provides: Low level functions: Connect, disconnect, servo control (position/speed), digital/analog ports.
Does not provide: High level functions: Playing sounds, video capture, gait control (walk, dance, move arms, etc), script/workflow execution.
2.1) Mono Applications The dll can be added to a Visual studio project targeting the mono platform and can be deployed on a Raspberry PI running a Linux distro: Raspbian, Lubuntu, etc.
2.2) Xamarin Development The dll can be added to Microsoft Xamarin project targeting iOS or Android. You build the application and is deployed on an emulator or an iOS/android device.
If your main objective is to develop a Xamarin application for a mobile device you don't need the Raspberry PI.
I recommend some reading: https://docs.microsoft.com/en-us/xamarin/cross-platform/get-started/introduction-to-mobile-development
Thank you very much ptp you have cleared a lot of ambigous things to me! :)
But i do have few more questions please...
Can i move the projects that i made with ARC into Xamarin? If not... One of the games that the ipad application provides is to show a video to the child and then pause the video. then the robot should ask the child questions about the video. And after the child answers; the video can resume to display the correct answer. As you can see; i need to be able to control when exactly should scripts starts and when they should pause.
So what is the easiest method i could do to achieve this? If as you said; Xamarin with mono does not provide high level functions :(
No. ARC projects are only useful for ARC Desktop/Mobile application.
What I said is the EZ-Robot Mono SDK does not provide high level features. That does mean you can't use Xamarin to build the high level features. Xamarin is technology behind ARC mobile application.
Feature 1: Playing video and multimedia features.
Feature 2: Play sound through EZB. The easiest way is to play recorded voice files.
Feature 3: Get screen (iPad) Input (screen buttons).
Feature1
Feature 4: I presume scripts are the gait/auto-position actions used to animate the JD.
There is nothing to convert an ARC project to a custom Ipad Application.
If you are .net developer, Xamarin will be an easy path to develop and deliver iOS mobile applications.
If you are Web/Javascript developer, maybe Cordova or React Native are a better way out to the mobile.
IF you are Mac developer: Xcode and Objective-C and Swift are the best tools.
bear in min whatever path you pick you will need to build the ARC high level features.
IF you need to recreate the low level features (EZ-Robot SDK):
EZB communication protocol https://www.ez-robot.com/Tutorials/Files/EZ-B%20Protocol%20Specification.pdf
C# Source code for Windows UWP (low level features): https://synthiam.com/Products/ARC
Then what did DJ Sures mean when he said that: " Xamarin is compatible with the EZ-Robot project to create a native app" and he also said that the ARC can be ported to a standalone xamarin app:
synthiam.com/Community/Questions/11466
I was using xcode but i switched to xamarin because i thought it could give me a better control over JD movements and scripts. stress
If i switch back to xcode; how can i build those high level features of speech recognition, dances, and playing audio from the robot?
Should i put the dll file into xcode project. And then i should use communication protocol to be able to use the low level features? Then what should i do to use the high level features? confused
I’m sorry i’m new to all these things so i might be a little slow tired
Hum.... this is not a new thread... started 2 months ago. is in your and the community's best interest to follow DJ's advice:
Context is everything:) ! This would save me time to try to guess what was your question and your goals.
I believe DJ's intention was to introduce you Xamarin the same technology supporting iOS ARC mobile app.
you have a lot of useful resources and source code: EZB communication protocol https://www.ez-robot.com/Tutorials/Files/EZ-B%20Protocol%20Specification.pdf
can be used to accelerate your App Development special the source code.
Asfaik there is no tool to convert an ARC project to a Xamarin project. If you are .NET developer and if you are familiar with Xamarin everything makes sense.
Quote:
Take a look at Xamarin first and get the environment up and running - so you can compile an app. Once you're familiar and comfortable using Xamarin, we can give you a few pointers on moving the ARC project to it
It seems you are not familiar Xamarin and you don't have any app ready, so now I understand why the confusion with Mono SDK/Raspberry PI.
Let's forget the Mono SDK, the above links is all you need to implement the communication with EZB. You have the protocol specification and you have c# source code that shows how to implement the low level features (DLL) plus playing sound on EZ-B.
After that you need to develop your app, the complexity depends on your developer knowledge. For example if you need to implement an auto-position feature, you will send a few sequence of servo positions/speeds to EZB. After that you can create a xml parser to read an ARC project's auto-position information.
Yes, you will be coding in objective-c / swift. The application logic is the same the programming language and APIS are different.
Forget the dll, does not work with a xcode project. Is only useful if you use with a Xamarin project.
The communication protocol is a doc file. You will need to code the protocol itself basically you will start by creating a TCP Client and sending commands to EZB. https://stackoverflow.com/questions/19003063/ios-simple-tcp-connection-example
code, code, code. Some examples: Play video: https://stackoverflow.com/questions/25932570/how-to-play-video-with-avplayerviewcontroller-avkit-in-swift State Machine: https://blog.codecentric.de/en/2016/07/handling-ios-app-states-state-machine/
I'm familiar with XCode and Xamarin, they are completely different environments one is aligned with Apple development the other one relies on Microsoft technologies.
IF you are new to software development, you have a lot to catch up before worrying with "high level" ARC features.
Whatever road you pick, you will need to master some development skills.
i can't thank you enough you have been a great help:)
well the thing is, i'm studying to become a computer engineer; so i took courses before to program in C++ and Java. i do have some development knowledge but it might not be efficient enough for this project. but the project deadline is on December so i believe i still have some time to learn and complete this project. btw this is my senior project so i really need to complete it in order to graduate. :D
for now i just need pointers on what should i start with; it's either xamarin or Xcode. so far; i liked Xcode interface more than xamarin. but from what you have mentioned it seems xamarin is a little easier. since it has C# source code to help implement the low level features (DLL).
but why can't i use mono sdk DLL file in xamarin project instead of using the C# source code to code it. wouldn't that save much time and effort?
There's a process to creating something that involves multiple technologies like this. It's first important to outline the requirement, then break it into smaller projects, and finally combine them into one. Edit the sections yourself...
Requirement a robot that has an onboard controller (raspberry pi) and a mobile interface. The main controlling happens on the raspberry pi and remote control features are triggered from mobile interface
Smaller Projects
  1. Use ARC on Windows with EZ-B v4 and get a robot to perform the features that you wish as a prototype. Use auto position, camera control, speech recognition, etc..
  2. Use Mono (linux) or UWP (windows iot core) on raspberry pi to duplicate the functionality from #1
  3. Create a TCP server on the raspberry pi to accept connections for remote controlling the functionality in #2
  4. Use Xamarin to build a mobile app that transmits commands to the TCP server on the raspberry pi
@DJ Sures thank you, you have simplified the process for me with those 4 points. :)
but i need a little more details.. since i already have ready projects on ARC on windows; i have completed the first point. i would like to ask you some questions regarding the second point..
Quote:
2) Use Mono (linux) or UWP (windows iot core) on raspberry pi to duplicate the functionality from #1
to duplicate the functionality from #1, do i have to use emacs editor to have .cs file and then use mcs command to generate .exe file and after that i execute it with mono?
but what do you mean exactly by duplicate? do i have to code the movements of the robot from scratch? or are there available instructions on the mono sdk that can perform those movements of the robot such as auto position, camera control, speech recognition, etc.. or is there a simpler way where i can port the whole project or some scripts of the project to the raspberry pi?
sorry for asking a lot.. tired and i really appreciate your help! :)
