Openai Dall-E Image icon Openai Dall-E Image — Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands. Try it →
Wiring Specification For Extensions
Does any one know how to add extension wire to the servo wire connector without cutting or modifing the black clip end and does any one know if the replacement I2c port cable able to just clamp together like an extension wire or does it have to be cut and modified or can it use general same gage wire modded to it like servo extension wiring, cuz I trying to find a cheap way to finish my project on spare wires from old toy robots, so stage one of project omega can be completed and readied for programming. Any ideas?
#18
I have used the long header pins from old project boards (arduino) to extend the camera cables with great luck. Remove the pins from the header blocks,and put them in the plugs. Be sure the pins seat in both plugs and for security place some hot glue on the plastic connector to assure the plugs stay secure. I connected three cables together and it works fine. Radio shack sells headers, and boards which have these headers. Ron
