ZAMA Emotion Model icon ZAMA Emotion Model — Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors. Try it →
Twitter
Windows Performance
Latest rock pi x installed windows and followed instructions but antivirus still appears in security settings even though I renamed the windows defender directory.  I noticed there was another one called Windows Advanced threat protection.   Also antimalware is running consumes a lot of ram as well can't stop process. I assume this is another directory I need to rename. crawling through the services there are a lot running has anyone been through all of these in terns of what we can shut down (do I really need a print spooler)
Is windows 11 more stream lined on an SBC because windows is really not designed well to run in a small amount of RAM / Slow CPU? Life was so much easier when you just had a config.sys and autoxec.bat file to contend with.
Rock Pi X by Radxa
ROCK Pi X runs Synthiam ARCx as an onboard x86 robot brain for browser control, vision, voice, scripts and EZB I/O.
Servos ✕
ADC ✕
Digital ✕
Twitter
Great thanks appreciate you documenting this.  Squeaking out the last bit of performance.
